Question about Iomega 1TB Desktop USB 2.0 Hard Drive
P/N 31677000 Model MDHD10T-U2 The drive was arranged as a back-up to the internal drives. It worked fine for a good period of time. It the spontaniously stopped working. A consistant clicking sound is evident but the drive does not appear on the desktop. Is there something haywire with the read/write mechanism?
5 Suggested Answers
SOURCE: 1T external will not mount on Mac OSX. It worked
This needs to be formatted before it can be used on a Mac.
  1. Launch Disk Utility by selecting ApplicationsUtilitiesDisk Utilities
  2. Click on the active partition to select it.
  3. Click on the Erase tab.
  4. Select MS-DOS (FAT) from the Volume Format drop-down menu.
  5. Click on the Erase button.
  6. When Disk Utility is finished erasing the disk, click on the active partition and ensure that the Format field at the bottom of the Disk Utility window says that the volume is MS-DOS (FAT32).
  7. You can now quit Disk Utility.
Posted on Oct 29, 2009
cowboytech
  • 69 Answers
SOURCE: I have an Iomega terrabyte drive model MDHD10T-U2.
If it did this when you first got it, you should have returned it for a refund or exchange. That drive was bad out of the box.
Posted on Feb 13, 2010
SOURCE: Iomega terrabyte drive MDHD10T-U2 does not mount, ticking noise
I had the same problem and after testing the drives seperately I found them to be in good working order I realized it had something to do with the IOMEGA enclosure. I transfered the drives to a new NexStar MX enclosure. Be sure to read the instructions as you have to move a toggle to the "UP" position. Everything worked fine with no data loss.
Posted on Feb 22, 2010
  • 451 Answers
SOURCE: eGo portable hard drive works with desktop with
right click on my computer and choose manage.
computer management will appear.
go down to disk management
if you see your ego drive listed there
right click on it and choose change drive letter and paths
choose a drive letter that isn't in use like F or G.
you should now be able to browse or view the ego drive in my computer. or by going to run and type the drive letter you choose.
Posted on Mar 04, 2011
I've lost the power cable for my 1tb mdhd10t-u2. Trying to order a new one but I need to know what to order. What's it called?
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Apr 26, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Service code U2-05? How do you fix this and do i need to call a professional?
That normally means the hard drive has failed. You can remove the hard drive and it will work except for I believe it is stapling and some other finisher feature.
What you can try is this.
Press # * C * , or as sharp calles it P * C *. The machine will enter diagnostics.
Then enter the number 16 as if making 16 copies. Then press start.
It will say something like U2 trouble clear.
Press start, then select 1 for yes and press start again. Repeat that a couple of times then press clear a few times or turn the power off then back on.
Nov 05, 2010 | Sharp MX-2300N Color Copier
I need the driver for Panasonic model SD-100A-U2 external optical disk drive
Please help me. cause I lose this driver
Oct 19, 2010 | Panasonic Computers & Internet
I followed richiegrier solution above - my drive began clicking and did not run. I determined both drives worked and that it was the power supply (apparantly I'm not the only one with this problem. I purchased a NexstarMX dual HDD enclosure. I opened it, flipped the switch up to the JBOD mode, and installedd my two drives. Initially the configuration recognized a single 900+ GB drive, which was empty. I used the safely remove hardware icon, powered down the unit, and switched the positions of the drives - VOILA!!! the computer recognized the drives and all the files are back online, precisely. A couple caveats - the drives when in JBOD mode are A and B, although there is no obvious way to tell them apart - Like a book, A appears to have the directory for the combined drive. When mounted in reverse, the computer did not read the directory, and assumed it was empty. When I reversed the drives, my drive came up, flawlessly with no input from me. THANK YOU. Do not format or create a new partition or you will lose data. I also purchased a 2 TB drive for back up, and will immediately begin a second copy of all the data on this drive so I do not have a disaster. Thanks again for saving me from disaster.
Dec 07, 2009 | Computers & Internet
1T external will not mount on Mac OSX. It worked fine but just stopped. Have tried other computers and cables but nothing. It is getting power. Model #MDHD10T-U2 Serial #JPA7470874
Oct 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I HAVE A IOMEGA HARD DRIVE FOR MY MAC (TIME MACHINE) MODEL NO. MDHD10T-UE AND HAVE BEEN USING IT FOR SOME TIME HOWEVER IT HAS NOW GONE OFF MY SCREEN AND I CANNOT RETREAVE IT I HAVE TRIED CHANGING THE...
Hi I had one which my son connected the wrong power cable to an toasted the boards inside. I had to strip it and get new boards for the hard drives inside and replace them. i have managed to recover one of the drives ie 500gb.
Oct 11, 2009 | Office Equipment & Supplies
I have a 1 Terabyte Iomega hard drive model # MDHD10T-UT Serial # JPA80302B8 I just stopped showing up on my desktop and I can not mount it. I have tried Disk Warrior, Data Rescue II and FileSalvage....
The Drive is not damaged - the power supply has failed it has happened to me 3 times.
Currently Im trying to get additional power supplies from Iomega. If I get additional info I will updated
Jul 30, 2009 | Computers & Internet
Edge DiskGo HD-D2-U2 External Hardrive not recognized by Vista
Hi
I having samsung E-250. I want to load dictionary in my mobile .How can I do that
Apr 08, 2009 | Peripheral Enhancements DiskGO! Hard Drive
The drive fails to be recognised by windows.
USB devices can be flaky and there's no end to stories like yours. I've had a couple, however, that were resolved by simply going into the hardware screen, removing the device, restarting the machine and letting Windows redetect it. It should have retained the driver and will reload it. Also, make sure its not a cable problem... Good luck!
Dec 17, 2005 | Zoltrix Zling U2 MP3 Player
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
427 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
