Question about HP Compaq nc6220 Notebook
Where is the bios battery??? - HP Compaq nc6220 Notebook
What is BIOS password?
No way to know YOUR bios password.
If you've neverassigned a BIOS password, press enter without inputting anything.
If you have a BIOS passwoed, you can reset BIOS rmoving CMOS battery
laptop cmos battery
Tutorial How to replace the CMOS battery in your laptop
How to Clear Your Computers CMOS to Reset BIOS Settings
How to clear an unknown BIOS or CMOS password
Apr 01, 2015 | Computers & Internet
How to bypass bios password for samsung NP-N102S
There is no magic software that will reset the BIOS password if you forget it. The only way to clear this problem is to remove the BIOS battery. Also, unplug the power cord adapter and remove the main battery before you remove the BIOS battery. If your in a hurry, after removing the small round BIOS battery short out the two pins the battery was plugged into to totally drain the capacitors on the motherboard. No harm to the motherboard, your just discharging any left over charge on the capacitors. The BIOS battery is usually under the keyboard and this will have to be removed to get at the battery.
Regards,
Dennis
Mar 27, 2014 | Acer Aspire Computers & Internet
SONY MXB-130 MS02 MOTHERBOARD DIAGRAM
Most laptops do not have a BIOS button to reset the BIOS settings.
To reset the BIOS just remove the BIOS battery and wait for approx.20 mins for the battery charge to discharge then replace the battery.
OR
After removing the BIOS battery just short out the battery terminals on the motherboard with a paper clip, the replace the BIOS battery and go into the BIOS setting to change the Date and Time etc.
There isnt a fuse for the LCD screen.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | Sony VAIO VGN-FS640W Notebook
How do I change the battery on my PC?
Yes you need to install a new BIOS battery. The old BIOS battery is flat and it cannot keep (store) the BIOS setting. Most motherboards use a coin size lithium 3 volt battery type CR2032 button battery.
Check the type of BIOS battery your motherboard uses.
When you replace the BIOS battery, go into the BIOS and set the Date and Time.
Nov 17, 2011 | Computers & Internet
I have IBM ThinkPad computer A22m 2628 and i have fogotten the BIOS password...how do i get it fixed
Remove the main battery and unplug the CMOS battery if you can get to it or you can try to hold the on/off button for about 30 seconds. This should reset the BIOS to factory defaults and you can then get back in and reset a new password.
Sep 25, 2011 | IBM ThinkPad A22m 2628 Notebook
HOW TO REMOVE PASSWORD FROM BIOS
Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
Feb 04, 2011 | MPC Computers TransPort X1000 Notebook
I need to reset the Bios password. I cannot reset the bios to the original settings. what jumper is used for this job and how exactally is ist done ? I've never done this and have been told that it is the...
To reset the BIOS back to the default settings and you cannot locate the reset jumper, just remove the BIOS battery for approx. 30 mins.
This will discharge the battery voltage in the BIOS, then insert the BIOS battery back and you can go into the BIOS configuration and set the Date and Time etc.
Jan 26, 2011 | DFI AK75-EC Motherboard
Forget bios password on nec laptop versa
The BIOS password may be removed by removing the BIOS battery from the notebook for 20 mins. If you cannot wait for this period, then short out the battery contacts for a few secs.
Replace the BIOS battery and go to the BIOS configuration and set the Date & Time etc.
If this procedure does not work then try this WEB site for BIOS passwords :-
http://www.biosflash.com/e/bios-passwords.htm
Oct 07, 2010 | NEC Versa SXi Notebook
Clear bios password D945 GTP
just reset your bios..you can remove your cmos battery and wait for a while then put it back again.. it should reset your bios also your bios password. the cmos battery is a regular wrist watch battery.. or cell battery..
Dec 13, 2009 | Intel D945GTP Motherboard
Qosmio g35 bios
You need to take off the main battery as well and leave the BIOS battery out for at lease 1/2 + hour for the BIOS to discharge and reset.
Then reconnect the Bios battery, plug in the power adapter, but not the main battery yet, power up the laptop and configure the BIOS settings/date etc. After it reboots you can now insert the main battery.
Dec 14, 2008 | Toshiba Qosmio G35-AV650 Notebook
HP Compaq nc6220 Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
