Question about Haier HLH406BB 40 in. LCD HDTV
When im hooking up my audio from the stereo reciver to the audio output on the back of the tv sometimes the audio doesnt work when i turn the tv on, I have to turn the tv on and off a few times before the audio will acually pick up again, my stereo reciever is old but it works great! Compatibility issues? help!
  • Anonymous Mar 16, 2014
    digital audio out has to be unplugged and plugged back in every time the tv turns off
  • 73 Answers
You want to hook it up to the audio input on the tv not the audio output.
Posted on Aug 07, 2010
  • williamgd2 Aug 07, 2010
    I am not sure what you want to do.Do you want to play your tv sound through the sterio receiver? If that is what you want then the you want the audio output of the tv to go to the audio input on the sterio receiver.
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
No sound from xbox to stereo using an optical out from TV to amp
If Im reading this right what you need to do
is hook the audio from the xbox to the stereo system
not to the tv .
Apr 04, 2009 | Samsung SlimFit TX-S2783 TV
How can I hook up a speaker system to my Dell 37 inch TV?
USE THE AUDIO OUTPUT RCA JACKS TO A STEREO RECIVER TAPE OR DVD INPUT
Mar 20, 2009 | Dell Televison & Video
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
My video out on my home theater system wont work.
your reciver probabily wont pass progressive through it, Hook the audio from the box to your reciever, and the video directily to your tv, thats a better way to do it anyway, your tv has alot better video prossesor than your reciver , or hook both audio and video to your tv, and run audio output from your tv to the reciver
Jan 11, 2009 | Sony HT-C800DP System
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Problem hooking tv to stereo
lwsmith91 you need to make sure that there is only one audio output on your stereo. if more than one try plugging it in to both outputs. also make sure that you do not hear any sound when you plug it in or its the wrong one. on the back of your tv make sure you dont have them plugged in to an HD input or output for that matter
Feb 28, 2008 | Televison & Video
Tv hook up!?
First you must be on the audio outs in back of tv set. then you must go into menu, if not already and change audio to varible output, or external speakers or just what ever yours say in menu. then you must turn receiver to the right inputs to get sound. Hope this helps.
Sep 21, 2007 | Panasonic SA-HE100 Receiver
Haier HLH406BB 40 in. LCD HDTV Logo
259 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
