Question about Kitchen Ranges
HOW DO i CHANGE THE CODE ON MY EA25 SAFE? - Kitchen Ranges
  • 4,323 Answers
Hi
To change the code open the safe, press the red button and the yellow light goes on, indicating that enter the state to change the code. Input the new code (1 to 8bits), then press ‘B’ or ‘A’ button, it will be confirmed by two beeps, indicating that the new code have been accepted and stored. However, if the yellow flash with the buzzer beeps three times means the new code is invalid and should operate again.
Hope this helps
Thanks
Daniel
Posted on Aug 07, 2010
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Manual for Kingavon safe 25
    www.tayabally.com/digitalsafe/.../Safe%20EA25%20Installation%20Instr...
    SELECTING A LOCATION. Your security safe should be installed in an isolated, dry and secure area. For greater security the safe must be fastened to solid ...
    Locksmithing: Kingavon electronic safe, first three digits ...
    Nov 24, 2015 | Locks & Locksmithing
    Change code
    If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
    Nov 23, 2015 | Home Security
    I need to reset my combination to my mesa safe
    This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
    If you changed the Master Code you will need to use the code you changed it to.
    Deleting your current User Codes:
    Input * - * lock will beep twice
    input 6-6-6-# lock will beep twice
    Input current Master Code - # lock will beep twice
    Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
    Re-input user number - # light stays green for 3 seconds
    Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
    This will delete user 5
    Unsuccessful code change: five beeps, repeat the steps.
    Changing User Codes: Code length can be 3 to 8 digits long
    Input 4 - 4 - 4 - # lock will beep twice
    Input Current User Code - # lock will beep twice
    Input User Number - #
    Input New User Code - # lock will beep twice
    Re-input New User Code - # light stays green for 3 seconds
    Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
    That example will change user code 2.
    Unsuccessful Code Change: five beeps, repeat the steps.
    There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
    The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
    Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
    Need replacement key 747 for a Cathedral Electronic Safe
    Im in a bit of a mare, I have a cathedral electronic safe, model ea25 but cannot find the overide key and as such when I put my combination code in it does not accept it
    How do I reset the combination code to get it to open without having the override key?
    Aug 18, 2013 | Home Security
    I need to change the code on the safe
    Safe? You are aware that this got posted under "Cars & Trucks"? I think you will get a better answer if you post your question under the correct heading and provide a lot more information like WHAT KIND of safe are you trying to change the code on? I am an automotive technician, not a safe-cracker, but I can tell you that if I was, I would want to know what make and model of safe I was trying to crack (or change the code on).
    Jan 02, 2012 | Cars & Trucks
    Change code
    Try this
    Open the safe.
    press the red button on inside of door
    entry the new code you want followed by B
    Should be good
    Nov 22, 2009 | Safe International Digital Electronic Safe...
    How to unlock a cathedral electronic safe ea25
    After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
    inside of the door near the hinge.
    2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
    3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
    If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
    If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
    BATTERY REPLACEMENT
    This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
    To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
    YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
    TROUBLE KEY
    A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
    If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
    Nov 01, 2009 | Home Security
    Changing the code on standleford es20 safe
    If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
    If you have the sentry key, open with key, and there is a red button inside the door to reset the code.
    If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
    Nov 07, 2008 | O2 Xda Atom Exec Smartphone
    Changing the code on my Sentry Safe S3877
    how to change the on sentry safe s3877
    Sep 29, 2008 | Sentry Fireproof Safe
    Kitchen Ranges Logo
    279 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Marvin
    Marvin
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
