Question about Kenmore Elite 45986 Front Load Washer
Washer Is Dribbling Water Into Tub
My washer is continuing to trickle water into the tub when the cycle is complete. Tub is slowly filling with water. Any ideas?! I thought maybe we had gotten excess suds and cycle stopped or something so I did the drain and spin cycle - but water continues to dribble.
  • MichelBNeb Apr 27, 2008
    THANK YOU! And where do I buy this valve at?
  • Kenmore Master
  • 2,651 Answers
You have a bad inlet waer valve stuck in open position, youll need to replace the valve. easy enough to do, its the valve your hoses are screwed into, in the mean time until repair is made, you can simply turn offf water supply between loads ( not a bad thing to do anyway)
Posted on Apr 27, 2008
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
The water, there was no water left in the tub of the washer, but the clothes were dripping wet; and the cycle was showing to be complete. I had to re-set the dial to the spin setting inorder to completely...
What has happened is that your water pump has gone out and it cannot pump the water out of the washers tub. This is a common issue and replacing the pump is not that hard assuming you have the time, effort, tools and energy.
Jan 23, 2011 | Kenmore 24962 Top Load Washer
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
125 people viewed this question
Sal De
 Brian Main
Brian Main
