Question about Zanussi TD4112W Electric Dryer
The drum wont go around and it smells like its burning.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
If you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Posted on Aug 06, 2010
Frigidaire gallery dryer
Possible lint blowing around on the heater coil. That burning smell is like paper burning. Get the dryer cleaned.
Make sure there is nothing sticking to the inside of the drum from previous drying.
Oct 17, 2013 | Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
Washer wont spin, smells like burning rubber
The burning rubber smell is coming from the belt which goes around the drum and is driven by the motor. The belt has probably stretched and is now slipping. It will need to be replaced.
Jul 13, 2011 | Washing Machines
I have a Kenmore Dryer Model number 66902691 that has a burning smell when it is running. All lint was just cleaned out of it, but it is still smelling!
This might be caused by a seized idealer pully, located on the bottom of the dryer drum. A belt wrapes around the drum and across the idealer pully and then on the motor pully. If the idealer is not turning freely, it creates friction and eventually burns the belt in half.
Hope this helps
Apr 29, 2011 | Washing Machines
Drum rotates and then motor locks up. Burning smell comes from machine with continued operation. Drum rotates free by hand. Drive problem or motor?
replace your belt ... the motor does not smell like burning rubber, the belt will exzude that odor.
Pop the top ... remove the front ... use care with the door switch wires.
the drum will come free of the unit.
Put the new belt over the drum, through the tensioner on the bottom, around the motor pulley.
You will need help ... put the drum back on the wheels inthe back and replace the front ... snap the top down
while it is apart, clean the exhaust system completely
Nov 02, 2009 | LG WM0642H Front Load
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Zanussi TD4112W Electric Dryer Logo
280 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
