Question about Panasonic NV-FJ620 VHS/S-VHS playback VCR
We had a number of power outages one night and the next day the VCR is dead, no display or anything what so ever. The fuse in the plug is ok and the line fuse in the unit is good as well. There is mains voltage across the internal fuse but there doesn't appear to be any low voltage. Nothing looks burnt or frazzled. Any clues would be helpful. Thanks.
  • Malcolm Parsons Sep 10, 2010
    I have now found the problem. It was the voltage regulator. Its generic name is STRG 6352 but the Panasonic part no. is c5haczz00002 and this is available from chsinteractive.
    President:
  • 894 Answers
Well it might be broken now you should go with a dvd player because they are better and are easier to care for and most of vhs is on dvd too.
Posted on Jul 28, 2011
After power outage front display blinking "16".
I had a similar issue where after a power outage, the player would not power up.
I removed it from power and took the cover off looking for a fuse. Could not find anything so I put the cover back on and plugged it in and it worked. My theory is the electronics needed time to fully discharge in the circuits. I would leave it unplugged for about 24 hours. I left mine unplugged for several days. I hope this helps.
Feb 13, 2016 | Toshiba SD-3990 DVD Player
Battery Back-Up not coming back on after power outage. Charged for several days without anything plugged in with trip button pushed in. Surge side still working. No beep light or anything on battery...
Does the unit have a breaker on the back? There may also be a fuse. You should be able to find a users guide on the CyberPower website.
If the unit may have failed during the power outage.
Jan 07, 2013 | CyberPower Computers & Internet
Turned TV off at night. Next day went to turn TV on but it was completely dead. What happened?
If there was a power outage durring the night it is possible that the power supply or the TV mother board could be effected-- even if there was a thunderstorm.
So in this case you can also check to see if the fuse if blown as a protection or that the SMPS is damaged.
Please remove plug remove rear panel to get access to the circuit.
see the link for tips on SMPS repairs.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jun 16, 2011 | Televison & Video
I have a Sharp VC-H982 VCR. Went to turn on today and it is not getting any power. Worked fine last night. I have moved the power cord to a different receptical, still nothing. Is there a fuse that may...
Hi:
If the unit is totally dead meaning no standbye light of or nothing on the display its dark, then you may of blown the AC line fuse. This is the first thing to check the fuse is inside the unit you can trace its location by taking off the top of the VCR and tracing the pwr cord to the point where it connects to the power supply, here is where you will find the AC line fuse use a ohm meter set on continunity to check the fuse for open condintion. If open or blown replace with same voltage and Amperage rating as indicated on the board or the fuse itself. If you find the fuse is good then you have a power supply standbye voltage missing and is related to the power supply. In which case it may be cheaper to just purchase another.
May 28, 2011 | Sharp VC-H982U VHS VCR
We had a power outage. TV and video both now dead. Changes fuses in plugs, still dead. Could the fuses in the appliances be blown ?
HELLO
Power outages can damage electronic items!
It is certain that the fuses in each of the units power supplies will be blown but I would recommend that you get both in for servicing as sometimes changing the fuses INSIDE and trying them again CAN cause more damage - and more cost to repair.
Better to be safe than sorry! (:-)
Oct 21, 2009 | Sony Televison & Video
Proform 570 blowing fuse
there are generally two control boards, I am assuming you looked at the lower one. I would first disconnect the power leads at the board and see if it still blows the circuit breaker (fuse?). If it does the check wiring for short. If OK then reconnect power leads and then disconnect all other wires (plug-ins) to the board and try again, each time plug a connection in and retry. (remember to disconnect power each time). I have a feeling the smoke got let out of this lower board and may need replacement. hope this helps
www.twincityrepair.com
Mar 01, 2009 | Proform 575 Crosstrainer Treadmill
Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Reset clockdue to power outage.
hi, this worked for me
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
this has to be done fro the main phone system
hope it helps
Jul 09, 2008 | NorStar M7310 Corded Phone
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
