Question about Samsung Heating & Cooling
Air conditioned Samsung AQV12VBC cod error:E1-01
4 Suggested Answers
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
hvac1960
  • 2133 Answers
SOURCE: my air conditioner show up a E1 error code, its a
Replace indoor room sensor.
Posted on Jan 01, 2011
  • 405 Answers
SOURCE: my portable air condition will not work when
HI.An E1 codes means that you need to clean the filter.Need toclear out debris that. May block the flow of air.
Posted on Jul 24, 2011
E4 flashing on Samsung air conditioner AQV24TWDN WHATS IT MEAN DONT HAVE MANUAL.
Do you see any other digits alternating with the E4? Most of the error codes that I know with Samsung split system air conditioning units have three digits after the E. Depending on the last two digits, the error could be with the control board (printed circuit board), the fan, a sensor connected to the control board or the wiring. See https://removeandreplace.com/2017/08/15/samsung-split-system-air-conditioning-ac-error-codes-and-troubleshooting/ for some ideas.
I found the User Manual for the Samsung AQV24TWDN here: https://www.samsung.com/au/support/model/AQV24TWDNXSA/ . Scroll down or use the Download User Manual link. The direct link to the manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_AU&CttFileID=5078406&CDCttType=UM&ModelType=N&ModelName=AQV24TWDNXSA&VPath=UM/201401/20140107175828476/Australia_AQV30T@_IBIM_33367A_E_1.29.13.pdf&OriginYN=Y .
Please add a comment with the full error code for your air conditioner.
Jul 19, 2018 | Samsung Heating & Cooling
Fuji air condition error cod coming EEE
When EE:EE is displayed on remote control , press "Energy Save" & "Zone Control" buttons simultaneously for longer than 3 secs.
Jul 22, 2016 | Fuji Cameras
2001 santafe with error cod PO420
CODE PO420 - CATALYST EFFICIENCY BELOW THRESHOLD BANK 1. POSSIBLE CAUSES, AIR LEAKS AT THE EXHAUST MANIFOLD OR IN THE EXHAUST PIPES, BASE ENGINE PROBLEM HIGH ENGINE OIL OR COOLANT USAGE, CATALYTIC CONVERTER IS DAMAGED CONTAMINATED OR HAS FAILED, CONTINUOS ENGINE MISFIRE CONDITIONS OR WEAK LOW COIL OUT PUT, FRONT HO2S OR REAR HO2S IS CONTAMINATED WITH FUEL OR MOISTURE, REAR HO2S IS LOOSE IN THE MOUNTING HOLE CHECK IT FOR A LEAK.
Aug 16, 2011 | Hyundai Santa Fe Cars & Trucks
Greeting, I have problem with SAMSUNG air condicioner inverter. The display shows me an error E1 A1 and does not include the external unit, please help what is the problem.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Jan 24, 2011 | Samsung AW1203B Air Conditioner
I am getting E1 error in my window Samsung 1.5 T a/c can u please hep ?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Aug 30, 2010 | Samsung AW0503B Air Conditioner
Problem with samsung aw0503b
Found this on Samsungs site.Hope it helps a little, at least you know the problem now. If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced. If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced. To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Aug 02, 2007 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
658 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
