Question about Sharp R-1210 Microwave Oven
I am installing a new power board on a Sharp R1214 microwave. It is all plugged back in except the last two have identical plugs and I don't want to plug them into the wron place. One has white and gray wires in a yellow plug the other has red and black wires and a white plug. The control board is marked RY1 on the top plug and RY2 on the bottom. Which way do these go (I should have paid more attention when I took it apart!!) Thanks, Lynn
  • 677 Answers
Use this link (http://www.youtube.com/watch?v=BHcO5HBenK8). Hope it help.
Posted on Aug 06, 2010
My Oster microwave. Last night we had a pretty big storm, this mourning I tried to use my microwave, No power. I switch plug in outlet ...Nothing happens. How do I get the power back on ?
Depends on what blew, if ti is a power surge is will blow out the low voltage transformer on the main board before it will blow the fuse in the unit, so Probably will need new main board. Problem will be finding someone who carries parts for Oster Microwvaes.
Oct 05, 2017 | Oster Microwave Ovens
I need a new transformer for my Sharp Microwave Model # R1214 - the part number is RTRN-Bo68MREO (1100 watt microwave)
The part number has been changed to RTRN-B098MRE0. You can find it new on the Sears parts site and at Encompass parts. There's a used one available on eBay for quite a bit less. Given its cost, when the high-voltage transformer fails, most people find it's cheaper to replace the oven.
Jul 14, 2011 | Sharp R-1210 Microwave Oven
When plugging in a Sharp R-33st microwave, nothing happens except a flashing time, no buttons seem to work, any ideas?
it sounds like this is not a new microwave,, is it getting on in years?
if the microwave was discounted from the mains when it was pluged back in the power surge could have blown the circuit bord inside it,, this is quite common, it may be cheaper just to buy a new microwave than spend good money on an old week unit
Mar 05, 2010 | Microwave Ovens
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Sharp R-1480 failed after a power outage
It's most likely the low voltage transformer that's part of the circuit board or a blown trace on the board. The HV transformer would only burn and smell if the unit was in a cook cycle.
The complete board assembly is only around $80. If you're really handy, you can order just the little transformer, but you'd have to remove (unsolder) the old one and install (resolder) the new one on. The circuit board is one assembly and it takes all of 30 minutes or less to replace from start to finish.
Check with Martin Microwave Inc. @ 1-877-894-0035 to order or to inquire.
Oct 30, 2008 | Sharp R-1480 Microwave Oven
Hit with 220V and now nothing.
I think the control boards are still available for this unit. No doubt the '220' blew the front end of the power supply.
Oct 25, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp r-1481 950 Watt microwave oven problen
Found the answer by calling a Sharp technician and they said it was the magnetron tube, which is not worth fixing :( Thought I'd pass this on to anyone that has yet to find out.
Oct 15, 2008 | Sharp R-1481B Microwave Oven
Display only shows 8888 - display buttons do not work.
try a reset. unplug for 10 mins, plug it back, see if it will work.
if not , open the housing, see a ribbon cable from the touch pad to the main pc board. remove the ribbon cable for 1 min. re install it back and test the unit.
be sure to return all cover and screws of the unit before plugging it back. microwaves are hazardous to your health.
tnx 4 using fixya,
drcool
Oct 05, 2008 | Sharp Microwave Ovens
LCD DISPLAY ON SHARP MICROWAVE R1214 NOT WORKING
We repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 28, 2008 | Sharp Microwave Ovens
Replaced capacitor but now light won't come on
Do you get anything on the display when you plug it in? If not, then the magnetron temperature fuse may be blown, too.
Did you get all the connectors plugged back into the circuit board if any were removed?
There may be a relay problem on the board. The following service manuals on our site may help you:
http://www.microwavedisplay.com/r1850_sm.pdf
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
http://www.microwavedisplay.com/R1874_sm.pdf
I also do board repairs. Please feel free to contact me directly if you need more help.
prototech@usa.net
Jun 17, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp R-1210 Microwave Oven Logo
37 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
