Question about SAMTRON 77V 17" CRT Monitor
Monitor no raster power has been ok - SAMTRON 77V 17" CRT Monitor
    President:
  • 1,099 Answers
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Posted on Aug 06, 2010
Toshiba 24" led tv mo. 24ps1e VGA is ok raster snow is ok ,after connection of cable only chroma picture seen,no Y signal.
Try to reset it to the factory settings and Them remove the power cable for atleast 5 minutes but Will be better to power OFF for 12 hours
Jul 18, 2013 | Televison & Video
Monitor plain raster ok but nodisplay (or) no image
check video output ic and resolder..then check vga cable..
Jan 04, 2010 | Samsung 793S 17" CRT Monitor
Nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Nov 06, 2008 | Computers & Internet
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
Moniter problem
first thing it is not necessary to replace eht when there is no raster.
  • you please go as per procedure.
  • check output from power supply
  • if is ok check horizontal section
  • if it is ok or eht ok then check for heater glowing
  • check video output supply & print open
  • check g2 voltage on crt base.
  • check crt base for loose.
  • check for signal coming to video output ckt.
  • for ckt you can refer modern color monitor ckts volume 1&2.
  • available in india.
  • hope this will help.
  • good luck
  • be in contact with me unless it is rectified.
Oct 17, 2007 | LG Studioworks 700S 17" CRT Monitor
SAMTRON 77V 17" CRT Monitor Logo
107 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
