Question about Nitro BMW-461 Car DVD Player
I need Power plug harness re-placement where can i buy it
  • 6,826 Answers
Ebay.com may have it, Bestbuy.com may have it too.
Need to know the year, make, model of car and the proper harness adapter can be provided that plugs into the original harness and has all of the needed wires labeled for easy aftermarket radio installation.
Posted on Aug 06, 2010
  • wcaudell Aug 13, 2010
    already have harness for for factory adaptor just need power plug for the unit 16 pin is needed
I am swapping in leather seats. New drivers seat is 10 way, with memory and heat. What wires should have 12v and ground to get power to the seat?
And it won't. You probably jumped too many years, And definitely the plugs. 6 to 10. Power and ground is there, Just at the wrong spot. You need pin outs for both. Alldatadiy.com. You can buy them both.
Mar 26, 2016 | 2006 Ford Explorer XLT
I have a 1998 Toyota Camry...Trying to hook up an Alpine...Need to know what wires to connect to the alpine.Car Wires are same with grey spots.....
From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Sep 03, 2014 | Car Audio & Video
I need a wiring diagram for a 82harley sportster
http://www.ebay.com/itm/HARLEY-DAVIDSON-SPORTSTER-MAIN-INTERCONNECT-WIRING-HARNESS-70482-07-/161682525353?hash=item25a5078ca9&vxp=mtr
why cant you buy one???,there are alot of them for sale,or by the headlight harness only,
HARLEY FL FX SPORTSTER HEADLIGHT CONNECTOR PLUG 3 post CHOPPER BUILD
Jan 01, 2013 | Harley Davidson XLH 1000 Sportster...
I want to change my F-150 radio, basic, with a radio/cassette/cd, will I need a different harness?
You will need a harness adapter for your model truck. This you will want to solder and heat shrink over the solder joints (Dont just twist tem together) then just plug it in to the factory harness.
You will probably need an adapter kit also.
The wiring harness adapter should come with the color codes for the wires corresponding to your trucks speaker and power wires pinouts make sure you correctly connect them to the color codes of the stereo for proper speaker placement and voltages
Mar 13, 2011 | 2006 Ford F-150
I need to know which colour wire from the radio is for what, so i can fit a non standard stereo
My best advise is not to cut the stock wire harness plug. Go online or to your local best buy and buy a wiring harness that will plug into your stock plug and into the radio. then you don't need to know what any wires are. cutting the stock harness is opening a can of worms.
Dec 23, 2009 | Car Audio & Video
I need a wire harness for a Cobra 40X CB or at least a description of how to hard wire.
I'm not sure I understand what you mean by wiring harness. If you are trying to wire it to power, and need the power wire, they are widely available. Its a universal plug for cb radios.
Ebay for around $5 search for CB power wire.
Truck stops usually carry stuff for cbs and they will most likely have one.
If you are talking about wiring the mic..... Just buy a mic for it already wired to the plug.
Dec 05, 2009 | Cobra Radio Communications
Need to install cd player in 97 wrangler. need to know which wires are speaker ground power etc.
easiest thing to do is to go to best buy and buy a radio harness kit for $15-20 which will plug ontop of your radio harness so you don't have to splice any wires. the kit is a plug on one end and labeed wires on the other end that will tell you where everything you need is to install a new cd player in such as your power, ground, remote, and speaker wires...much easier to do then to splice and trace each wire.
Jul 11, 2009 | Wrangler Jeep Twin Stroller
VR3 cd 400 where to get wiring plug to go in back of player
Do you need a wiring harness for the back of the unit? All you have to do is google "wiring harness for vr3 cd400 and you will have allot of options to choose from. If you connected the red which is 12v +, yellow connects to 12v for radio memory, and black goes to ground. Brown is for external amp turn on. Check to make sure your connections are correct. Do you have an adapter harness that plugs into the factory radio harness? You can get one from Wal-Mart or best buy or online. So you don't have to cut/splice into the wiring harness coming from the stock radio.
Aug 25, 2017 | Virtual Reality Sound VR3 CD Player w/ USB...
I need electrical plan for pluging my radio ,for toyota echo 2005
If you are attempting to install an aftermarket radio Don't butcher the plugs on your Toyota ... simply go to a car stereo shop and buy an adapter plug for $10-$20 then wire it to your new radio ... then just plug them together (the wires on the adapter are marked) You'll likely need a dash kit too ... save yourself from a lot of frustration time and money! ....
May 08, 2009 | 2005 Toyota ECHO
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
Nitro BMW-461 Car DVD Player Logo
46 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
