Drive not being Unlocked.
I installed Easy Lock Drive 4.0 n locked my G drive.n when I tried to unlock the drive,it displays unlock succesed but still my drive is not being accesed.what should I do?
my email id is -- nishikant_ramnani@yahoo.com
    President:
  • 1,257 Answers
Just uninstall the software from control panel add/remove programs..if still problem continues try to delete its entry from reigistry...but if you are unfamiliar with registry just go to
all programs > accessories > system tools > select system restore and when it opens click next now select the previous date on which you have installed your software ..for ex, if you have installed your software on 5 april select the date like 4 april or any previous date.. it will definitely solve your problem.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Posted on Apr 30, 2008
  • Deeps . May 01, 2008
    Best Methods to resolve the problem :
    Update to obtain the latest service pack for Windows XP
    Possible causes of this error may include the following:• Hard disk damage :
    • General hardware configuration problems with the BIOS, the memory, the hard disk, or with other devices
    • Incompatible device driver
    • Incompatible software
    RESOLUTION:
    Method 1: Use the Windows Error Reporting toolMethod 2: Method 2: Remove any hardware or any software drivers that you recently added.
    Start the System Restore tool at a command prompt
    Restart your computer, and then press F8 during the initial startup to start your computer in Safe Mode with a command prompt.
    Log on to your computer with an administrator account or with an account that has administrator credentials.
    Type the following command at a command prompt, and then press ENTER:
    %systemroot%\system32\restore\rstrui.exe
    Follow the instructions that appear on the screen to restore your computer to an earlier state.
    Unplug any new external hardware devices, and then try System Restore. Start System Restore as appropriate for your situation.
    Method 3: Run Windows Update, and perform a Microsoft OneCare full service scan
    Regards :
    dilipbagdi
    Technical Associate
How to unlock my local drive if it was locked by "easy drive lock software"??
To unlock the hard drive unlock x:
The x represents the letter of the hard drive that you want to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
To lock the hard drive lock x:
The x represents the letter of the hard drive that you want to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jan 25, 2014 | Computers & Internet
Need help with imac im locked out
Problem: Your Mac got locked via iCloud and on boot displays "Enter your system lock PIN code to unlock this Mac." It also sets an unknown password on the firmware so you can't boot from a disc. And you don't know the PIN code for a variety of reasons (not my business).
Solution: Mount the locked drive on another machine, find the PIN, re-install the locked drive into the original Mac, enter the PIN, resume your business.
Tutorial:
*I'm going to post the steps I did in my case and suggest steps you might take if your case varies.
Things Needed:
1. Alternate machine with space to mount an additional drive. (works on Mac or PC*)
*If you're using a PC, you'll need to download and install Mac Drive to be able to read the contents from a Windows environment.
2. You might need a SATA to USB adapter if you have a laptop without room for an additional drive.
3. Screw driver to disassemble the Mac.
Step 1: Remove the locked hard drive from your Mac.
You can find detailed guides for your specific machine at http://www.ifixit.com/Device/Mac
Step 2: Install the drive into your alternate machine. But make sure you do *not* boot from it. Boot from your regular drive.
If you do not have an alternate machine, feel free to ask a tech buddy of yours to lend you their machine.
Step 3: Once booted into the alternate system, locate your locked drive.
In my case it was drive D: on Windows. Now browse to \Users\username\Library\Application Support\iCloud
Step 4: In the folder "iCloud" find a file named with a bunch of numbers: ##########.lock In my case it was: 1138515150.lock
Step 5: I'd suggest that you take a picture of this file name for accurate reference. But you can also just write it down.
Step 6: Once you got the number, power down the machine and remove the locked drive.
Step 7: Install the locked drive back into the original locked Mac.
Follow your iFixit guide from Step 1 in reverse to put the drive back.
*It is important that you put it back in the machine where it was originally locked* so that the motherboard firmware will be unlocked in the next step.
Step 8: Boot up the locked Mac and referencing the number you recorded, you can start trying 4 numbers at a time for the PIN.
Try the first 4, then the second 4, and so on..
For example: 1138, 1385, 3851, 8515, 5151, 1515, 5150.
In my case the PIN was the second to last 4 digits: 1515
If you typed in more than 10 combinations, then it says that you are locked out for a minute. Just restart the machine and continue entering the combinations from where you left off.
Once you enter the right PIN, the Mac will instantly reboot proceeding to where you were at when the lockout occurred. It will also remove the firmware password.
Mar 15, 2013 | Apple 21.5" iMac Desktop
BAD DISK BECAUSE PASSWORD LOUCK
Issue How to lock / unlock the hard disk drive.
Cause
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
  1. Attempting to install another operating system.
  2. Attempting to fdisk the hard drive.
  3. Installing software.
Solutions
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
Jun 16, 2011 | HP Computers & Internet
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
Washer displaying du code with 3 quick beeps
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Dec 27, 2008 | Western Digital Passport WDXML800UE...
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Computers & Internet Logo
David Payne
David Payne
