Question about Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan
I just bought a cooling pad Logitech n100. The usb-cable is connected correctly to my notebooks (I tried it with 2 Dell laptops, the Inpiron 640m and the Latitude E6500), but .I don't see the fan spinning
    Novelist:
  • 105 Answers
Hi Andries, I would suggest to try on different usb ports, but you've already did on two laptops and i don't think possible all of their ports are not working.
I can say that the N110 is often thought not to be working because it's really really quiet and as for keeping low consumption levels the fan doesn't move a big deal of air, so it may seems switched off also if it's working. Anyways, if you double check and see it's completely off don't waste your time (also because there are NO switches on it, it's supposed to work instantly when you plug it) the only thing you can do is to bring it back to your retailer and get a new one or ask for a refund. Regards, Peter
Posted on Aug 06, 2010
  • FProtection Dec 18, 2010
    I have a Logitech cooling pad for my Dell 17" Studio laptop with 4 GB RAM and Vista Home Premium. It mysteriously stopped working. When I plug the cooling pad in other laptops, it works fine. I have tried attaching the cooling pad to other USB ports on my laptop with no results. My USB ports work fine because I connect other USB devices to them.
    Please help. Is there some power setting in Vista that I have to turn off?
Keyboard failure
This may be an issue with your usb drivers. Update those first, then if that fails, I would try one of those adapters that goes from USB to the old school mouse and keyboard connections and plug that in to see if it works.
Sep 24, 2012 | Dell Inspiron 640m Notebook
How do I disassemble my logitech cooling pad for cleaning?
Hi, I just did clean my logitech pad without any sratch. Here is how I did dissemble it.
There are 10 screws. 3 at the back of the pad, which can be removed very easy. Another 7 are under the shiny plastic part with whole for the airflow in front of the pad. It is easy to remove it. I used a wrapping ribbon (the ordinary for wrapping presents) and put it through the wholes in the top middle part of the cover, in the way you end up holding both ends of the ribbon. And gently pull the cover apart of the pad. It goes quite easy. Then remove the 7 screws (2 are hidden in the wholes with the white plastics)...and you can start cleaning. I did not remove the fen part itself. Its easy to clean it with an old toothbrush.
I hope this helps.
Feb 24, 2012 | Logitech Notebook Cooling Pad N100 Model...
My logitech N100 cooling pad has stopped working
first check the connetions at both ends of your cooling pad make sure the connection into your laptop is securely seated and its not faulty
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb pad but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jun 01, 2011 | Logitech Inc 939-000119 N100 Cooling Pad...
I have a Logitech cooling pad for my Dell 17" Studio laptop with 4 GB RAM and Vista Home Premium. It mysteriously stopped working. When I plug the cooling pad in other laptops, it works fine. I have...
Seems that your laptop's USB ports are not providing enough power to the cooling pad. This could be due to you connecting too many USB peripherals to your laptop. Test if you can get the cooling pad to work by disconnecting all other USB devices.
As a permanent fix, you can buy an active USB hub (one powered by external power source) & connect your cooling pad to it.
Dec 18, 2010 | Computers & Internet
My logitech cooling station stopped working! The fan for my logitech usb cooling pad N1000 stopped spinning and now my laptop is overheating. Is there anyway to fix this? Do I have to get a new one?
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by
warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some
good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Jun 15, 2010 | Logitech Notebook Cooling Pad N100 Model...
Dell inspiron 640m...laptop screen in back. it
Possible only 2 solutions 1,the inverter has gone out and the othere is a replacement screen!
Aug 08, 2009 | Dell Inspiron 640m Notebook
Battery Not Charging
Sounds like the power supply has gone bad. You should get a new power supply. You will get this message when he power supply goes bad
Feb 12, 2009 | Dell Inspiron 640m PC Notebook
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Logitech Notebook Cooling Pad N100 Model 939-000119 CPU Fan Logo
471 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
