Question about Lexmark E332n Laser Printer
I am trying to connect a Lexmark E332n printer to a network and it has never been assigned an ip address. I do not have the software that come with the printer and downloaded the driver off the internet. Is there any way to set the ip with out that software?
    Genius:
  • 1,354 Answers
Hi
go to following link you will have your Printer Drivers
http://bstdownload.com/reviews/lexmark-e332n-monochrome-laser-printer-driver/
Posted on Aug 06, 2010
WINDOWS VISTA LEXMARK 3500-4500 SERIES DOWNLOADS
The lexmark 3500-4500 series is a ip so one the device is conncted (ypu should assign it a fixed ip address from yourrouter) you should be able to find it in network printers
Feb 04, 2013 | Lexmark International Lexmark 3500-4500...
Pc and communication with printer
If your printer is already connected to your network, try to assign a static IP address to your printer to prevent it from getting a new IP address from your router. To do that, just get the IP address of your printer, open a browser and type in the IP in the address bar of your browser. Once you have the embedded web server of your printer, click on Settings > Network Ports > TCP/IP > Uncheck "Enable DHCP" > Submit.
Once you have set a static IP, resintall the Lexmark software. It would be best to use an updated driver. Just go to http://bit.ly/VuhrpF to download the updated driver. After reinstalling the driver, check if the firmware for your printer is up to date. Just go to http://bit.ly/PZaAmK to download the firmware update.
Jan 22, 2013 | Lexmark S315 90T3100 All-in-One Color...
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it.
1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer.
2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following.
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses.
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
We have Lexmark T654dn which is assigned IP and connect into network. How do I connect the this nerwork printer from Client Machine.
select add a printer in printer, select local printer, create a new port --> pull down menu to
standard tcp/ip port, printer name input ip address and it should find the printer, then
select the correct driver and that'sall
Mar 22, 2011 | Lexmark T654DN MONO LASER PRINTER
How do I pair up my printer with my new moden?
Hello Melissa !
What you need to do is to physically connect the printer to the modem, now your computer should be connected hardwired or wireless to this modem.
When you connect the printer to the modem , the modem will assign an IP Address to the printer, you can look on this ip address by printing a configuration report from the printer itself.
Now we have 2 options here, use the software that came with the printer (installation disc) to install the device and at some point of the installation it should detect the printer automaticaly, just remember choosing "network install"
If you already have the software on your computer, you will need to uninstall / reinstall the software so the computer can detect the new ip address. Or you can set the ip address manually by going under printer and faxes on the control panel, make a right click on the P4350 icon, go to properties, then the "Ports" Tab and click Add Port, you will need to select Standard TCP/IP, click new .. and then type the IP Address
This should connect your printer with your new modem - computer
Good Luck !!
You can contact me at:
eliteprintersolutions@gmail.com
Jul 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Mar 05, 2010 | HP LaserJet P2015dn Printer
Factory Reset
Remove printer drivers
Printer off.
Disconnect LAN.
Open front cover.
Hold/press both buttons on front, keep holding.
Turn on at back.
Only release button when all lights have stopped flashing, top and bottom light illuminated.
Close front cover
Connect LAN cable.
Reinstall via add network printer - will detect and reset new IP.
Apr 24, 2009 | Lexmark E332n Laser Printer
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
No communication between computer and printer?
I had the same problem with my X5410, installing on Windows Vista. After about 6 hours of working on it I got it resolved.
I uninstalled the Lexmark software from my computer. Start -All programs-Lexmark -uninstall.
I then turned on all components of Windows Firewall. Control Panel - Windows Firewall.
I then re-installed the Lexmark software from the CD.
Hope this works for you !!!
Dan
Jan 14, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark E332n Laser Printer Logo
214 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
