Question about Whirlpool RBD305PD Electric Double Oven
Whirlpool over (RBD305PDS15) display not working. The oven is 5yrs old and recently the display started gradually fading...now there is nothing. The oven still works, inside light still works and the buttons still beep. I've read 2 possible solutions: (1) defective display...replace Control Panel Assy (part #8300435), (2) defective ECC...replace Conrol Assymbly (part #8302319). The manual also lists 2 other parts, Control Panel Gasket (part #4451034) and a Sister Board Latch (part #8301848). Any advice on which part is required?
  • Greg Shepherd Aug 27, 2010
    The provided solution was WRONG. Ordered the part...had to return the part...had to eat the restock and shipping...cost me $50.
    As I have now found out, the Control Panel (recommended solution #1) is not the CPU...it is more like the keyboard (buttons only). The ECC is the correct part (#2 in my original question). The ECC is like the CPU.
  • 6,993 Answers
The first on the list is the cause of the problem and its the part the needs to be replaced.
The control panel is like a central processing unit (CPU), it controls all the function of the Oven. Usually, the control panel is the cause of most oven problems. The control panel is also know as the control board.
I am not say this because you listed list, but because that actually the cause of the problem. If you had not stated it, I would have still mentioned it.
Therefore, replace the control panel and your oven will be work perfectly again.
Good luck.
Posted on Aug 06, 2010
Whirlpool rbd305pds15 -- display works, there are no error codes. But oven randomly beeps, sometimes once then the next time multiple beeps. No luck disconnecting power for 12 hours
the computer board or clock assy. is bad and you can't get this part anymore the stove is to old and it says on the parts site that it's discontinued part WPW10438751
Nov 05, 2017 | Whirlpool Ovens
How to clear F2 E1 error on a whirlpool double oven
E1 F2 is most often due to a failed keypad. Depending on your exact model the original part may be no-longer-available. However, there are replacement membrane switches available here:
Introducing the Ledgestone Technologies Touchpad
Models: RBD305PDB10 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDB14 RBD305PDB15 RBD305PDB7 RBD305PDB8 RBD305PDB9 RBD305PDQ10 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDQ14 RBD305PDQ15 RBD305PDQ7 RBD305PDQ8 RBD305PDQ9 RBD305PDS12 RBD305PDS14 RBD305PDS15 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD305PDT14 RBD305PDT15 RBD305PDB1 RBD305PDB2 RBD305PDB3 RBD305PDB4 RBD305PDB6 RBD305PDQ1 RBD305PDQ2 RBD305PDQ3 RBD305PDQ4
Jan 08, 2014 | Whirlpool RBD305PD Electric Double Oven
My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Jul 13, 2010 | Whirlpool RBD305PD Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Clock fades
Sorry the only way to repair is to replace the control board
Mar 28, 2009 | Frigidaire 27" Built-In Single Electric...
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Display problem
you can replace the display, however you have to take the face apart
Apr 27, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Apr 02, 2008 | Whirlpool RBS245PD Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
696 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
