Question about IBM Wheelwriter 30 Typewriter
I got a label stuck on the roller of my ibm wheelwriter 30. the only way to remove the label completely will be to remove the roller. How do I remove the roller or is there any easier way to remove my label?
  • IBM Master
  • 3,594 Answers
At each end of the platen are black plastic latches, squeeze them together and lift out the platen.
DickyO
Posted on Aug 10, 2010
  • IBM Master
  • 5,568 Answers
While I haven't seen your model of machine in many moons, the roller was generally not difficult to remove once the plastic housing was removed.
If it appears to be a bigger job than I recall, you could take 1/4 - 1/2 sheet of plain paper, saturate it (not dripping) with naphtha (lighter fluid) and feed it into the machine to cover the label. Allow some time to soak, feed the paper out and wipe the residue of adhesive with a clean lint free rag several times, wetting it if necessary with a few drops of naphtha to complete the removal.
You might feed several clean sheets of paper through before using to ensure no residue or fluid has stayed behind.
Posted on Aug 06, 2010
4 Suggested Answers
  • 3594 Answers
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
Posted on May 16, 2008
  • 3594 Answers
SOURCE: IBM WheelWriter 30 Series II Operator Manual
The delay print and justify are both on the far rt. of the keyboard pressing these keys turns the features off and on. if this dosen't do it you're keyboard is bad.
DickyO
Posted on Aug 02, 2008
  • 3594 Answers
SOURCE: IBM Personal Wheelwriter 2 - machine comes on and is stuck
If the 1 &2 lights are flashing check the keyboard conectors and see my tip under WW1000.
DickyO
Posted on Dec 14, 2008
Label stuck behind platen. How do I get it apart to get it out.
On both ends of thplaten are black plastic latches. Squeeze them together and lift out the platen. When reinserting be sure they are lined up with the side frames an push down firmly it should snap into place.
DickyO
Sep 28, 2010 | IBM Wheelwriter 30 Typewriter
In typing a label, it got stuck on the roller and the daisy wheel. The only wat to remove the label was to remove the roller. I did that and replaced the roller. Now the daisy wheel is only printing part...
The platen (roller) is not fully seated in the side frames check to be sure the latches are lined up then press firmly on both ends of the platen it should snap into place.
DickyO
Dec 22, 2009 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 1500 is only printing the top half of the letters.
I have solved the problem. It turned out that the platen was not completely secured on the left end. Once I snapped it securely in place, the print was fine again. (I had to remove that platen three times to figure that out!) Sorry for the bother, but I'm glad to know where I can seek help now. Thanks.
Mar 25, 2009 | IBM Wheelwriter 30 Typewriter
Paper doesn't load properly in typewriter
The platen shouldn't be too hard to remove; what you describe could be caused by the residue of labels which can be removed by lighter fluid or pure alcohol.
If removing it appears too difficult, try putting a broad stripe of one of the above across the width of the paper and then try again moving it side-to-side.
Jan 29, 2009 | IBM Wheelwriter 30 Typewriter
IBM Personal Wheelwriter 2 - Machine comes on and is stuck with flashing lights on the left . . .
DickyO
Dec 11, 2008 | IBM Wheelwriter 30 Typewriter
ONLY TYPES TOP PART OF THE LETTER IBM WHEELWRITER 30 SERIES II
The most common problem is the platen (black roller) gets out of position. Be sure the black latches are aligned wuth the side frames then push down firmly on the ends of the platen it should snap into place.
DickyO
Aug 27, 2008 | IBM Wheelwriter 30 Typewriter
DickyO
May 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
294 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
