Question about Jenn-Air Kitchen Ranges
I have a jenn air electric wall oven. Model #WM27260B The broiler works but the oven doesn't. When I set it on bake 350 degrees. It takes 20-30 minutes for the oven to warm to 200 degrees and it won't get any hotter. What do you suggest? How do I repair it?
  • 4,323 Answers
Hi
Please check the connections to the bake element. To check these connections, you'll need to disassemble the Oven. Remove the two screws connected to the back of the oven, you would find it hard to remove them, use a rachet and screwdriver both. Now, check the electronic display it is held in place with four screws which can be easily removed with a screwdriver. To replace the element, remove the oven racks, take out the two screws. Now disconnect the two wires, and check the resistance, it should be between 1200ohms-1500 ohms. If it is not then then you'll need to replace the element. Please check the picture below---
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 06, 2010
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a JennAir Model JES9860BAS and the oven don't work
Well it probably is a faulty control but before ya blow any money on an oven control check the oven sensor. If it is open or grounded to the frame then the control cannot read the voltage sent through the oven sensor and know to shut down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn Air W241 bake element not working
Most ovens are relatively simple; an element and a switch/thermostat. Usually it's one or the other that goes bad. If you have a good Volt/Ohm meter you can test the parts saving you un-needed expense.
A Volt/Ohm meter will pay for itself in parts and safety.
A service manual with circuit diagram will go a long way in saving you time and money. Most service manuals are available online for free as a PDF file.
Happy baking. Photo is a pizza baked at 300 o F with Pizzacraft brand pizzeria flour purchased online.
Dec 15, 2017 | Ovens
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
