Question about Kenmore 27831 Top Load Washer
Kenmore Mod.#11027831600. When in spin cycle the washer shakes and move around the floor. I check that it is level. And that the clothes were in the evenly.
  • george ostendorp
    george ostendorp Aug 06, 2010
    how long has this unit been doing this
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27831600&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Aug 06, 2010
Kenmore 80 series washer shakes during spin cycle
Check to be sure your washer is level. If it is not then the bottom legs will screw up or down to level it. If that is not what is causing the issue then I would look at the load being uneven. If you move the clothes around in the washer does the shaking stop. That is usually the main cause.
Hope this helps,
Tami
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Oct 15, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Our washer shakes & wobbles durring the spin cycle I have the kenmore smartwash quiet pak 9. THE FEET ARE ALL FLAT ON THE FLOOR BUT WE JUST MOVED AND CAN NOT FIX THIS PROBLEM. ANY IDEAS?
ahh but is the floor level?
use a spirit level to see that the floor is actually level and distribute the clothes around the drum to stop it going out of balance. Of course you know that last bit you have been washing for years,but check the floor
Aug 30, 2009 | Washing Machines
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 07, 2017 | Washing Machines
Kenmore 27831 Top Load Washer Logo
185 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
