Question about Ovens
I bought a Sattler Holiday range/oven and don't know how to make the appropriate propane connections.
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
Posted on May 31, 2008
  • 10865 Answers
SOURCE: propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
Posted on May 20, 2009
  • 112 Answers
SOURCE: Repair or buy new oven.
replace the element....they are not that expensive.
Posted on Jul 20, 2010
aviral_srms
  • 1216 Answers
SOURCE: I have a Gaffers and
Sounds like the oven ignitor is weak. If everything else is working it must be a bad ignitor. These are usually easy to replace and can expect to pay $70-$100 for the part. Check to see if it glows when in bake mode first. If it does then replace the ignitor. You can look at the ignitor, when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced
Posted on Jun 28, 2011
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
Jul 20, 2010 | Ovens
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Propane not getting to oven... stove top works fine..
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Kenmore propane range/oven tripping GFI
My bad, yours is an oven.
I found the Owner Manual, but could not find the Installation Manual. Do you have it, and does it say to hook the oven to a GFI protected power source?
Just because of the way the electronics work in the oven, and the way the electronics work in the GFI, I don't think that they work together. The oven is a permanent appliance, so I don't know of any reason it would need it.
How long have you had this oven installed, and connected to the GFI? Has anything changed, like you washed the oven down and got water inside it. Is a non GFI circuit available nearby where you could wire the oven?
Let me know what you find. It's been awhile since I looked at a new Electrical Code (NEC) book, and even with that, you local ordinances can over ride the NEC.
Jan 29, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
May 22, 2008 | Amana Ovens
Viking range
on the back of each one of the gas valves including the one in the oven there should be an orfice which you can put a 1/2 inch wrench on and turn all the way in until its snug and also flip the cap over on the gas regulator so it shows "LP" this will convert the range to propane let me know how you make out and BE VERY CAREFUL
Sep 11, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
