Question about Refrigerators
I have a kenmore mini-fridge which is only a few years old. It works fine other than the fact that it freezes my food in the refrigerator section even when I have the thermostat set on the lowest possible temperature. It has a freezer which works fine but I would rather not freeze the food in the fridge section. Is this a problem I can get fixed?
  • Anonymous Mar 27, 2014
    freezer section not freezing but fridge section working fine
They do that when they are on the way to the big kitchen in the sky. sorry, but mini fridges do not typically last very long.
Posted on Jun 14, 2008
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Food at bottom of fridge freezes
Bad cold control switch.
The cold control switch should open when the set temperature has been reached. If the control does not open and turn the compressor off, it will continue to run and freeze items in the refrigerator section.
If the control is not closing, the compressor and all fans will stop operating. Check the control for continuity. If you don't feel comfortable checking this yourself, get a repair person out to check it out.
Hope this helps.
Aug 07, 2009 | Kenmore Refrigerators
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
My freezer isn't keeping foods frozen. It's an eight year old Whirlpool. The fridge section also isn't keeping the food as cold as it used two. I have turned both sections to max for coldness. I have...
You can have the freon checked or recharged, or you might have to take the motor apart and blow it out with air or pressure wash it. The compressor may be going bad most of the time it's cheaper to replace deep freeze instead.
May 01, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Apr 30, 2008 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Refrigerators Logo
758 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
