Question about Panasonic CT-27G34 27" TV
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
My Panasonic CT-27G34A standard definition 27" TV (1999) just recently started having a problem: the screen will jiggle/glitch up-and-down just slightly (maybe 1-3 scan lines in height) at random intervals and durations. I've verified that it is independent of which TV input I am using (ie. across 2 sets of RCA inputs, 1 coax input). It will do this jiggle/glitch at least once every 5-10 minutes, and will last for anywhere from a few seconds to a minute. But then it will stop doing this for many minutes. I also intentionally jiggled the various input cables lightly at the connection into the TV and confirmed that this does *not* cause the problem, so it's not a bad cable or TV connector. My best guess is something is wrong with the actual CRT scanning gun or electronics.
Any idea what is causing this? Is this something I can fix myself (I'm pretty handy with a soldering iron), or something a TV repair shop could fix?
  • 71 Answers
Sounds like dried up cap either in vertical circuit or power supply.
Posted on Apr 27, 2008
SOURCE:
Not DTV ready?
it meens the tv set is in dtv and the dtv conection is not set up.
hd tv is a red blue a green cable.
and the antena conection needs to come from a converter box if signal is coming from antena if from sat or cable you should have a hd box that feeds your set.
hope this helps.
daniel.
Jan 13, 2009 | Panasonic CT-27SC13 27" TV
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Pink screen
Anything is fixable just a matter of cost or availability of parts.
Jul 24, 2008 | Panasonic CT-27SL15 27" TV
Rings of Color
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Dec 13, 2007 | Panasonic CT-27SX12 27" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Panasonic CT-27G34 27" TV Logo
190 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
