Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
I am unable to do quick launch on my new k 300 keyboard
    Champion:
  • 219 Answers
Try reinstalling the driver software.
Posted on Aug 06, 2010
Tip
Quick launch in Windows 7
Here is what you need to do to enable quick launch in Windows 7:
Step1: Right click on Taskbar at the bottom -> select "Toolbars" -> click on "New toolbar..."
Step2: In the "folder" line in new window that opened up type in te text below:
"%userprofile%AppDataRoamingMicrosoftInternet ExplorerQuick Launch" (without quotes)
Step3: After typing in the text above click "Select Folder".
Step4: Now you should have "quick launch" at the bottom right and you can now right click the dotted line next to "quick launch" and drag it to your desired position.
I personally like it next to "Start" button just like the old days :-)
Amar Sondhi
on Jan 24, 2010 | Computers & Internet
Tip
Get back the Quick Launch bar Windows 7's new taskbar functions as a program...
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it:
1. Right-click the taskbar and choose Toolbars --> New Toolbar.
2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area.
It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title.
Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar.
You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
on Jan 12, 2010 | Computers & Internet
Hpp dv6 1115ee quick luanch notwotking
This model doesn't officially have Windows 8 support. That would be why the quick launch doesn't work. Also quick launch I believe for HP is only supported for Win 8 Pro and Enterprise versions, not the consumer version.
Jun 08, 2013 | HP Pavilion Computers & Internet
Dv4 1125nr remote control driver
I think the remote control is part of HP's Quick Launch product and the driver can be found under Mouse/Touchpad and Input Devices. Look for the Quick Launch or Quick Play which controls the Media devices such as the DvD/CD, etc.
In the excerpt below they reference the remote as the external easy access keyboard (I think). I got this off my daughter's HP which has a remote.
This package contains software that enables customers to program the Quick Launch Buttons on the keyboard and the external Easy Access Buttons Keyboard for the supported notebook models and operating systems. This application enables menu control of various buttons such as volume, internal/external display, and mute on/off.
May 21, 2012 | HP Computers & Internet
My computer is automaticlly turning down the volume and the Quick launch button for turning down the volume is flashing, as if you're pressing it.
it sounds as though the quick launch button is stuck down, have a look around the button to see if there is a build up of anydirt around the button which is causing it to stick, if you can get a pin down the edge of the button you may be able to gently lever it up so it no longer being activated.
Hope this helps
May 09, 2011 | HP Compaq 6730b Notebook
Unable to drag and drop files
let me whether u r not able to drag it from a folder to another or drag it to a start up or quick launch .
1. if you want to drag to startup grpoup or quick launch then go to :-
a. Right click on the task bar goto properties , select it
b.select start menu tab select customize
c. Again select advance tab and check the option Enable dragging and dropping. pls find it. it is in the second line .
now u will be able to drag and drop .
Jun 17, 2009 | Computers & Internet
Quick launch volume button turns red when Laptop boots
Right Click the Start button, choose properties, then select the taskbar tab. Remove the check mark next to "show Quick Launch".
What are you using for your media player?
Which OS are you on? When does the button turn red?
Mar 30, 2009 | HP Pavilion dv4000 Notebook
Keyboard
uninstal set point software then re-instal
I had same problem mouse was fine keyboard was a problem.
I un-installed the software and re-insatlled and keyboard now works. However I still have problem with quick launch keys, cannot get these to load, word excel etc
May 31, 2008 | Logitech LX 710 Keyboard/Mouse
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
27 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
