Question about Thomson DPL909VD System
Dvd909 thomson is dead .what is the reason - Thomson DPL909VD System
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
If no lights or standby light the power supply inside the main unit has failed best repaired by service engineer. if in uk spares available from www.tvs-services.com
Posted on Aug 11, 2010
Dead tv Thomson Quadra 20 inch
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 31, 2016 | Thomson Televison & Video
Thomson dv3 250
Thomson might be able to supply one.
Apr 28, 2014 | Televison & Video
I was cleaning out my caller id history. delete, delete, Oops. All of a sudden the phone went dead. message waiting light blinked. Battery was fully charged at the time and has been sitting on the...
Could be many reasons.
You could check this:
after removing the battery cover check that your connector is well inserted.
Look carefully one of battey cable may be cut or not in contact!
Dec 19, 2017 | Thomson Lands Phones
My thomson modem power light is the only light that works
either its no device attached to your modem or your modem simply dead .. turn off and on .. connect your pc to your modem and see the result ..
May 31, 2011 | Thomson Computers & Internet
Loss of connection to internet for no apparent reason
Can you check if this happens without the router ? if you connect your modem directly does it still drop at times ? If not , see if you can update the firmware of your router. that could help
Thanks Ranjit
Oct 07, 2009 | Computers & Internet
TV RCA THOMSON 27R411T CHASSIS ITC008FHM
Try replacing the eprom. If that somehow became corrupted due to HV surge or otherwise, you would have this symtom. The eprom contains information that basacally tells the HV circuit to turn on.
Apr 06, 2009 | RCA 27R411T 27" TV
Thomson scenium doesn't start when we switch it on.
First, try to unplug and reset. Second, Remove back cover and check for shorted horizontal output transistor with ohmmeter. If shorted replace flyback. Next, carefully disconnect plug connectors from deflection pcb. No need to disconnect h.v. or screen leads. Remove from plastic frame and look at bottom (solder side) for cracks around pins of flyback transformer. Resolder all pins. Last, look for two or three bulging capacitors in power supply on same board and replace. Any of these things can cause a dead set. Good luck, Russmann.
Dec 11, 2008 | Thomson Televison & Video
Thomson DPL909VD System Logo
164 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
