Question about Aprilaire 1700 Dehumidifier
I have an Aprilaire 1750 installed inline with my upstairs central air system in the attic. The unit's ducting appears to be installed as indicated in the installation manual, but when the unit is running on very hot afternoons, it is sending hot air to registers that are being supplied by ducting hooked to the supply plenum directly across from where the conditioned air from the dehumidifier dumps in. This causes a 20 degree dif ference in air temperature coming from registers in different areas of the upstairs, Why am I getting this hot air from the dehumidifier?
  • 20 Answers
Your dehumidifier is likely working correctly. When operating and removing moisture, a dehumidifier will supply warm/hot air to your house. Your dehumidifier moves less air than your A/C, so your supply ductwork in your house is oversized for the dehumidifier. This will lead to uneven feeding of your supply duct branches with just the dehumidifier operating.
Since your dehumidifier is installed in the attic, make sure that the ducting connected to it is well insulated. Also make sure that your dehumidifier cabinet is insulated. These actions will help prevent heat gain from the hot air in your attic.
Is your dehumidifier bringing in fresh air from outside? If the outside air is hot and humid, the dehumidifier will supply warmer air to your home.
Some people run their A/C fans continuously to help with the air distribution, but this is a bad idea since it increases energy usage considerably.
DryDog
Posted on Aug 06, 2010
My AprilAire 600 humidifier drips water from the bottom of the unit. I changed the filter and cleaned the parts. Could it be the hose running to the condensation pump that might be the problem?
its going to drip when it is off,it has built up humidity and has nowhere to go,leave it running and let it cycle by itself or cause damage to the system
Jun 24, 2015 | Aprilaire 600m Whole-house Humidifier With...
How does a humidifier pump stop
if your talking about a humidifier that's connected to a hvac system , there are two basic types , one uses a wheel similar to one a small pet rodent would exercise its self on , but this one is covered with a mesh that holds water, and a motor not a rodent turns it , fresh water is maintained in a dish in bottom of unit by a level activated valve ,it's activated in two methods one by airflow switch (paddle) and another by being connected to blower motor of air handler(electrically)
the other type is nozzle type , these need to be mounted in long straight runs of main duct work not more than ten feet from furnace (heat) these simply have a air flow switch that opens a valve to let house water into nozzle in duct , much smaller than 1st version unit
Jul 02, 2014 | Kenmore Dehumidifiers
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Sep 12, 2011 | LG LHD45EL Dehumidifier
My dehumidifier suddenly does not remove any water from the air. It worked perfectly last summer and just sat in the basement unplugged over the winter. I plugged it in a few days ago and it has been...
It may simply be a case that the air intake filter needs cleaning, as do the condenser coils. This is recommended maintenance, prior to using the dehumidifier for the first time each season. Also, the air temperature at floor level, may be to cool for it operate properly. Particularly, if it's below 60 degrees. the unit up off the floor and placing it on something sturdy, will help solve that issue.
After cleaning the unit, as stated above, try placing it upstairs where the temperature will be warmer and allow it to run at it's lowest humidity extraction level. That's usually 35%. If it functions properly upstairs, then you will know that it's an air temperature issue in the basement.
Hope this helped you troubleshoot and solve the problem.
May 26, 2011 | Whirlpool AD70USS Dehumidifier
580.53701300 low temp dehumidifier freezes up, no water, fan & compressor run constantly in basement 61 deg. F. Has sensor been declared defective and will Sears remedy by free installation &...
Although, this was a poorly designed unit, manufactured by Whirlpool for Sears's Kenmore line, I'm not aware of any recalls due to a defective sensor. I can tell you, that although the air temp in your basement may be 61 degrees F, at floor level the temperature can be as much as 5 to 8 degrees colder. This definitely, would affect the operation of the dehumidifier. Also, a dirty or clogged air intake filter will cause the unit to freeze up. As will dirty condenser coils. Cleaning the coils twice a year, is recommended routine maintenance. And regular cleaning of the air intake filter is a must.
What I would suggest, is that you perform the maintenance mentioned above and move the unit upstairs where it warmer and run the unit there for several hours. If it collects water there, with the humidity extraction level set at 35%, then you will know the unit works as it should and that it needed the routine maintenance and the warmer air temperature. Do not perform any maintenance until the unit has completely thawed and the unit is unplugged from the wall outlet.
Hope this helps you to troubleshoot and solve the problem.
May 26, 2011 | Kenmore 53701 Dehumidifier
Just bought, brand new. where to put water in? unit will not turn on.
If you bought a dehumidifier, you will not need to put water in it. A dehumidifier removes water. A humidifier add moisture to the air, and you need to add water to this. Was your dehumidifier running before and then it stopped? If so, it will have a tank on the bottom that will have water in it that needs to be emptied out. Let me know if this is your problem.
Sep 27, 2010 | Aprilaire 1710 Dehumidifier
Best way to relight the pilot without peezo ignition duct heater
You need to hold down the pilot button all the way down (turn selector to pilot).
When pressing the pizo count to 5 then press and repeat. It you just click it constantly you will lose your mind.
Jun 07, 2010 | Dehumidifiers
Dehumidifier will not run.
Have they messed with the wires to the humidistat??
Either they are unhooked or they shorted out the wires and burnt out the transformer...
heatman101
May 14, 2010 | Aprilaire 1700 Dehumidifier
The power board or control board may not be functioning properly based on the information you provided. In order to best assist you I would recommend you contacting your HVAC installer or contact Aprilaire directly for further insight on this particular issue.
Mar 25, 2010 | Aprilaire 1700 Dehumidifier
Unit freezes up and does not defrost
Sounds like the unit may be dirty or the fan is not moving enough air. Most Dehumidifiers do not have a defrost cycle. Air is drawn over the evaporator where moisture condenses and drops out, the air then passes over the condenser where it is reheated. The cool air helps cool the high side lowering system pressures and improving efficiencies. If the filters etc are clean and all the ducts and shrouds are in place and it still freezes you probably have a bad fan motor or possible a small refrigerant leak.
Good Luck,
Gilshultz
Dec 01, 2009 | Whirlpool Dehumidifiers
Aprilaire 1700 Dehumidifier Logo
377 people viewed this question
Top Aprilaire Dehumidifiers Experts
Michael Youngman
Michael Youngman
Gil Shultz
Bill Boyd
Are you an Aprilaire Dehumidifier Expert? Answer questions, earn points and help others
