Question about JCPenney Baby Gear
I can not get the side rail to stay up. Not sure of the brand. I bought it in 1980.
  • 340 Answers
Hello! This is Products America and we are the crib hardware specialist. We may be able to help you with your hardware needs. Our phone numbers are 800-205-9642 or 800-772-1041. We are open M-F 8 am-6 pm CST. We look forward to speaking with you!
Please check out our website at www.productsamerica.com.
Posted on Aug 06, 2010
Ford 150 XLT Gas Line Filter,
1980 to 2000 it is on frame rail under drivers side. keep in mind some trunks have more than one filter.
Sep 10, 2017 | Ford Cars & Trucks
Carriage
The rails are probably dirty & full of grit, just get a cloth & clean the rails upper & lower. Oil the rails when finished with light machine oil only.
Jul 21, 2014 | Office Equipment & Supplies
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
Need to buy carb rebuild kits I have a 1980 yamaha 1100 xs but I'm not sure after that where do I find the machine number like f;g;h; lg;l,etc.
G'day.
An easy one. Yamahas made in 1980 were all G models.
They made two versions of the XS-1100. A cruiser style & a standard type.
To get absolutly model spacific for ordring your carby parts, best get your engine & frame numbers first. Use them when ordering parts to increase your chances of getting the right ones.
Frame numbers on bikes (at least hear in Australia)are located on the steering neck(at the very front of the frame-written on a plate or stamped in).
Sometimes they are to be found on the L/H or R/H lower frame rail.
As for Engine numbers(road bikes)- They can be found on the engine case- usually R/H side near top of clutch cover.
I do hope that this was some how helpful
Regards Andrew Porrelli
May 13, 2011 | Yamaha FJ 1100 Motorcycles
1980 caddy coupe deville has brand new battery, brand new alternator but the battery keeps draining.
Something is staying on after the key is turned off. easy way to find out what is staying energized is pull all fuses, disconect the battery, then put the amp meter in line with the positive side of the system between the positive battery post and the positive cable end. then put the fuses back in one at a time a see which one draws one or two amps. that will lead you to the draw down circuit. If nothing is pulling the battery down then the battery is not getting a full charge. Check the ground conection at the motor side of the cable and also the ground strap between the motor and the firewall
Apr 18, 2011 | 1980 Cadillac Deville
How do i remove the front seats from a 1998 cadillac eldorado.
roll the seat all the way back and it should expose two bolts on the rails maybe inside the rails itself, there may be a plastic cover just remove that, then roll it all the way forward again if theres plastic covering remove it, should be two more bolts to remove and the whole seat with rails should come out.
Jun 21, 2010 | 1998 Cadillac Eldorado
My bathroom drawer used to stay closed, but with pulling by my toddler, it now slides open on its own. How can I adjust or tighten to make it stay closed?
the track rails appear to have come loose. Remove the drawer place a level on the track rail and tighten or reinstall the screws which held it in place. There will be one set of screws for single track drawers or one on each side of a two rail drawer.
Feb 21, 2010 | ACCO Brands Kensington Desktop Comfort...
NO LONGER AVAILABLE
Be careful with used cribs as they can be quite dangerous.
I'm not sure if your idea will work,as both sides of the rail need to be raised up and down. Or do you mean that both sides of the crib go up and down?
If I had a picture it would help.lol
Make sure that if you can't fix the sliding rail that you leave it at the highest position so that baby can't pull itself up when he/she gets to that stage.
You could try finding another one(for parts) at a second-hand store,yardsale,etc.
Good luck.
Sep 23, 2009 | Storkcraft Baby Cynthia 04550 Crib
Side rail
honest answer: take super heavy duty zip ties and tie the drop side in place in like 8 places to be sure it will stay put.
i did it with my crib to be safe when simplicity recalled theirs for rail issues, i would start with trying to get a hold of a person st simplicity for children your crib may be one of the ones recalled for rail failure issues then they would send you parts free
they should also be able to help you find out if the crib is theirs or not too
you should under the crib for a sticker with numbers, usually the model number / serial number and date of manufacture if you come up with a model number type it into a search engine online if manufacture name not on that label to find out who makes it, then contact them for pieces
hope that helped
Aug 05, 2008 | Evenflo Jenny Lind Crib
Baby Gear Logo
59 people viewed this question
Top JCPenney Baby Gear Experts
Tom Chichester
james laughton
james laughton
Are you a JCPenney Baby Gear Expert? Answer questions, earn points and help others
