Question about Nokia N97 mini Smartphone
Does the N97 mini have the Wi Fi function? - Nokia N97 mini Smartphone
  • 159 Answers
You may contact the service provider.......
Posted on Oct 28, 2010
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
Tip
Nokia N97 mini Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N97 mini mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N97 mini mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N97 mini without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97 mini.
3 - Compose #pw+CODE+1#.
4 - The Nokia N97 mini would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mini mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N97 mini
Each Nokia N97 mini mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia N97 mini mobile phone from the site http://www.unlock-zone.com/
on May 18, 2010 | Nokia N97 mini Smartphone
Why can't I find the HTCDriver on my phone, I want to use it as a modem
If you want to connect your laptop to the internet using your HTC Wildfire, one way of doing so is to connect your HTC phone to a mobile network (Globe or SMART here in the philippines), then use it as a Wi-Fi Hotspot (available on the menu, android 2.2.1). Then, check for Wi-Fi connections at your laptop.
P.S. Same phone here, but not yet tried to use it directly as a modem, like I used to in my old N97.
Jan 29, 2011 | HTC Wildfire Cell Phone
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
I have trouble when opening up certain webpage, i
contact your service provider u have some problem with access point or u r not subscibed to use internet.
u can use it via wi fi if u want
Oct 27, 2009 | Nokia N97 Cell Phone
I need to unlock my nokia N97 that is on 3 network
Only way for now is to get it from 3. There's also some "unlockers" but all what you will get is reflashed cracked OS with signal loss and problem with wi-fi and 3G.
Oct 25, 2009 | Nokia N97 Cell Phone
Nokia N97 mini  Smartphone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
