Question about Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher
Unit would not drain, found soapy water in unit. Checked for obstructions...None found...start cycle then hit cancel/Drain and nada...no noise, no drain...nothing...Entered the diagnostic mode on the unit and reads E1 which describes a heat problem?????Pretty proficient at fixing things, need a little guidance...Please help...
  • rleblanc313 Aug 06, 2010
    Macmarkus....Control panel is in the door?
  • Bosch Master
  • 2,605 Answers
Welcome to Fixya.
I can provide you with a complete service manual in a "pdf" attachment, but I`d requre a email address.
I know what the problem is, though you may not like it.
The reason your dishwasher is displaying a "1" is the control has detected a heating error as you said you`ve confirmed thru diagnostic`s.
Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further.
Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on Aug 06, 2010
  • 3 more comments
    The control board is in the door?
  • Mark MacDonald
    Mark MacDonald Aug 06, 2010
    yes it is.
    macmarkus :)
    Macmarkus....Thank you very much....I will let you know if I need the pdf file on the breakdown as I do not like to publish my email address....Thank you for your expertise.
  • Mark MacDonald
    I understand.
    I hope to have a windows live account set up in the near future with these available, but it`s more work than I thought.
    Good luck, let me know,
    macmarkus :)
  • rleblanc313 Aug 11, 2010
    Macmarkus...OK fixed that problem...Thought I was done...Hit cancel/drain and it drained the unit no problem, however when I did a quick wash...after it was done, water still in the bottom..run test cycle and it shows E6 code...It says Aquasens (Aquasensor?)...Is this going to be a problem with the safety overflow device? I did pull the unit out, cleaned all hoses and assemblies, washed out with a hose and put it all back together. Also, since I had to pull it out, I may not have gotten it level as the installer, what is the procedure for that? Eyeball it? It is close, but I don't know how critical that is.
    Problem Solver:
  • 15 Answers
Have you tried the simple option first? I had a drainage problem and solved it by running a cycle with one of those Finish liquid dishwasher cleaners, letting the unit go through a normal cycle and drain into a washing-up bowl (easier draining as it was entering flood protection mode). I couldn't see any blockage in my drains either but there must have been something in the path to the sink as this cured it.
Posted on Aug 22, 2010
5e code displayed someone came and looked at it - everything was fine - ran through a cycle and showing the code again
This is what I found for you:
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Check your drain system and verify the unit can drain water. If you have too, remove the drain hose and drain into a bucket to verify it can drain. This could be from some obstruction within the hose or air-gap or disposal, however you unit drains. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Samsung Dishwashers
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
Pump Problem with Calypso. I was getting the FL code on my washer so having read all the suggestions on the internet I removed the pump assembly and checked for obstructions, nada. Impeller is...
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Jun 04, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
MAV7000 clicking sounds in all cycles. sounds like a fan blade hitting an obstruction. noise volume decreases a bit when spin cycle occurs sounding like gravel. Spin locked up once. Strange metallic odor...
Sounds like there is an obstruction striking or rubbing against the impeller in the drain pump assy. It will require removing the front cover/ Drive belt from the bottom of unit/ Hoses from drain pump (be prepared for the water) a 3/8" socket to remove the pump & a needlenose plier to remove the obstruction... Hope this helps....Bill
Mar 04, 2009 | Maytag Atlantis MAV7000
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
1,504 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
