Question about PW Calpump Pw5500 Waterfall Pump 5750 Gph 3/4 Hp
Cal pump PW4500 new 2010 model, they say , 3 days old , runs 10 hrs. a day on a timer . pump stopped , took a amp load check ,draw was10.6 amps. pulled pump out of the water ,took inlet screen off. turned impeller with my finger has to much drag on it.to start, like the bearings are bad.how can you tell the old model from the new 2010 model. Marvin gardens has not returned me e-mail yet, for warrenty service. thankyou Andy
I have a Hobart am 14 with a new pump motor drawing high amps
Search Results
    Dishwasher Electrical Problems - Chapter 6 - Dishwasher ...
    www.appliancerepair.net/dishwasher-repair-6.html
    If the dishwasher is loaded with a lot of food residue, it will need extra rinse cycles .....changes, they will be explained in instructions that come with the new timer. ... If you have an ammeter, the stalled motor will be drawing 10 to 20 amps or more. ... Since the resistance of the heater is very high compared to the resistance of ...
    Pump Repair FAQ - OTP Industrial Solutions
Nov 26, 2015 | Hobart Dishwasher Am-14 Commercial Dish...
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Oct 31, 2012 | Hardware & Accessories
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
13 month frig quit running
Here is what I would do:
I would check to see if the compressor and condenser fan motor is running.cc8d7bd.jpg If the compressor was hot to the touch that would give me a clue.
That would tell me the relay is stuck in start mode causing the compressor to get hot and quit.c6b5f66.jpg I would remove the relay and put my HS410 start pack to see if the compressor comes on and I would check if it was over amping. The amp draw should be around 1 amp. If it is running 7 or 8 amps then the compressor is shot will over heat and die.b261986.jpg The fan motor by the compressor should run when the compressor does. So if the compressor is running but not the fan then you need to look at buying a fan motor. If the fan is running but the compressor is not then you need to buy a relay. If all of that is ok I would next listen for the fan motor blowing in the freezer, no fan no cool. Lots of times fans will make a racket if ice begins to build in the evaporator.c4cad85.jpg They will get louder and louder. Then the ice will build to the point the fan won't blow.
I would need to check for a bad defrost heater or terminator if that is the case. Do this test: unplug the ice box and let it sit for 3 or 4 days till it completely thaws out. Then plug it back in. If it begins to work ok then you KNOW you have a defrost problem. Replacing the defrost thermostat and heater is not very difficult, you still need to let it thaw out to do it. Even if you called me out there and I said it was a defrost problem I would still have to leave and come back 3 days later. If you suspect it is the defrost then go ahead and clean out the ice box and let er sit for 3 days. Then until you can fix it just unplug it once a week like grandma did back in the 40s before auto defrost. That's all the smart pills I have. Post a model and I could be a bit more specific because you could have adc0c1e867.jpg or a timer a control board instead of a mercury based control and in that case their is much more to check. For instance if you had an old schoo timer,8c078f4.jpg it might be stuck in defrost. It might just take moving that timer screw forward to get it unstuck. Don't know until I see a model number. More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Goodman 3 ton heat pump - condenser fan motor gets hot and stops running. Have tried 3 motors. Heat of the day it stops.
did you get a motor with the same amps? did you check to what the amp draw is on the old motor to the new? reason is different amp ratings on motors need dfferent blade pitches, also 2,3 or 4 blades pull different cfm. is the motor a belly band mount or does it hang by studs? also check to see if the capacitor is the correct uF. hope this helps you feel free to ask any question if this does not help you.
Jun 08, 2010 | Goodman CKL60AR60 Air Conditioner
Machine keeps shutting down,pump won't draw water into machine and then shuts off. Have to turn off and on many many times before it will start picking up water and recyle the machine. Machine is only 2...
These brewers (especially B77, usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
Feb 13, 2010 | Keurig B70 Coffee Maker
PW Calpump Pw5500 Waterfall Pump 5750 Gph 3/4 Hp Logo
63 people viewed this question
Top PW Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a PW Garden Expert? Answer questions, earn points and help others
