Zenith phonograph turntable spins unevenly - Audio Players & Recorders
  • Joemath2 Apr 27, 2008
    That seems like a reasonable solution.
    Sergeant:
    Champion:
  • 319 Answers
I assume you mean the t-table turns with unsteady speed (?)
Or do you mean the t-table is bent, edge moves up and down in relation to the frame.
If speed is unsteady, have unit completely cleaned and lubricated and replace idler wheel
Posted on Apr 27, 2008
Turntable won't spin. I need a manual; does anyone know where to find one?
Most of these very old turntables used an electric motor which turned a rubber wheel that pressed on the rim inside the platter. No spinning would indicate that either the motor has stopped or the rubber wheel is not touching.
As far as service manuals go I doubt you will find anything on line. Your best bet is to go to a main library in some big city that has a section dealing with technology or mechanical engineering. They might have servicing books for Radio and TV engineers for the 1950's which cover the model.
Apr 02, 2015 | Audio Players & Recorders
Turntable won't turn pyle pro
Are you sure that the motor is actually spinning and if it is there is a belt that drives the capistan drive
Apr 19, 2014 | Pyle Pro - PTCDS2UI - Classical Turntable...
Phonograph Repairs
As this is a very old unit, there may be dozens of mechanical reasons for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 25, 2013 | Audio Players & Recorders
Model number on Zenith Solid State Stereo Phonograph
The label has likely been removed or come off, most of those had it on the rear or bottom with a few inside where the phono is.
Dec 11, 2012 | Televison & Video
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Jul 15, 2009 | Audio Players & Recorders
Why can't I get my regular speakers to work on my turntables?
Yes, you need to connect a turntable to a amplification source. Phonographs send a very low level signal. If you decide to get a receiver/amplifier be SURE it has a PHONOGRAPH input - Many new models do not. If you simply plug it into a receiver without one (and the ground screw) your sound will be unpleasent.
Jun 04, 2009 | Sony PS-LX300USB Turntable
The Radio,Cassette Player/Recorder. and CD Player all work. The Phonograph Does Not!
if it arrived by mail then the sender might have screwed the transit screws down to avoid damaging the phono , i am not familiar with memorex but if like most turntables there should be some big screw heads visible on the top of the phono or possibly even under the platter all you have to do is unwind the screws until the platter unit moves freely [you should be able to push it up and down a little bit ]
May 23, 2009 | Audio Players & Recorders
Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
Apr 17, 2009 | Audio Players & Recorders
Phonograph vs Cassette Player
Is your needle tight.  It has to be tight for it to work
Oct 20, 2007 | Crosley CR248 Turntable
162 people viewed this question
 Grubhead
Grubhead
