Question about Jenn-Air JES9860 Electric Kitchen Range
I have a jenair electric range that the broiler works but not the oven. If I set the oven on bake 350. It takes 30-40 minutes for it to get to 200 degrees but it will not get any hotter. What should I do to fix it?
I have a jenair electric stove and oven and cannot figure out how to turn the oven on to bake. Any suggestions?
Posted on Aug 17, 2010
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
I have a model MER5755QAS. Oven/broiler not working right.
Sounds like you may be getting only 110v to unit. After unplugging, Check for any burnt wires around terminal block or around elements. Also first check if breaker may have half way tripped. Cut breaker for stove all the way off and then back on. The bake element may have partially tripped the 220v breaker thus only sending 110v to unit.
Oct 31, 2017 | Maytag MER5775Q Electric Kitchen Range
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 15, 2009 | GE JBP30 Electric Kitchen Range
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
146 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
