Question about Ruud Heating & Cooling
Looking for air filter for rudd ubhc-24j11sfe
2 Suggested Answers
SOURCE: My son has a Rudd
If you pull the bottom door off, or where the blower motor is, the filter should be with
sight.
Posted on Sep 03, 2011
How many tons is a rudd model ubhc-14j06sfd?
I believe the "06" in the model number has been reversed. It should read UBHC-14J60SFD. This would make this unit a 5 ton unit. I hope this helps:) Have a great day!
Jun 18, 2014 | Ruud UBHC Air Conditioner
Ubhb-21j11sfdai: what motor should be in this blower? HP, RPM, Voltage, Amp?
If you have the motor from the blower, the information should be on the motor nameplate. If there's no nameplate or information on the motor. Then to get the correct motor for your blower, you need to call your local Rudd dealer or local parts store. Give them the model number and serial number of the Rudd unit and they should be able to help you.
Jun 11, 2013 | Ruud UBHC Air Conditioner
My son has a Rudd air conditioner Model UBHC-17J11. Where is the filter located?
sight.
Aug 28, 2011 | Ruud UBHC Air Conditioner
I have a rudd hot air gas furnace,ignitor sparks
to carmelmontgo; do you have a smart gas valve sometimes the wire connections get loose. remove wire connector then reinstall. also cleaning a flame sensor will work if the flame sensor is good. I would check the ground connection sometimes contaminated with rust. also I would check the gas pressure with a gas manometer...my email is alpharomeo@windstream.net
Jan 20, 2010 | Ruud UBHC Air Conditioner
We have a Rudd acheive 90 plus (11 years old) that fires but will not stay running. Any suggestions?
I have not worked on any Rudd 90s but in some furnaces a flame sensor on the opposite side from the igniter can get dirty. It looks like a 0.08 " wire sticking out of a ceramic holder.Cleaning the wire with scotchbright will often cure the problem . Good luck
Nov 04, 2009 | Ruud UBHC Air Conditioner
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
When my Rudd air conditioner/heat pump is running, water pours out of the bottom of the unit. What could be causing this?
It's working properly. Air conditioners make it feel cooler by removing humidity from the air.
Aug 04, 2009 | Ruud UBHC Air Conditioner
We are a HVAC company and we have a customer with a rudd A/C and i need to talk to a tech is there a number for Rudd Company not a HVAC company
Isn't there a Rheem-Ruud dealer in your area. They could tell you. The # for the plant in Ft. Smth, Ark. is 479-648-4900
Jan 22, 2009 | Ruud UBHC Air Conditioner
Rudd AC Leakage
unstop the drain line
Aug 13, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
116 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
