Question about Nautilus Tr300 Treadmill
The tread will not go around. The electrical system seems fine and turns on as usual, the incline goes up, but when I turn up the speed nothing happens. Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The motor controller is faulty and needs replaced
Posted on Aug 11, 2010
My Sole F63 was working fine. One day, after we unplugged the treadmill and plugged it back in, the treadmill went through a start up process. It elevated the desk for a couple of seconds and stopped and...
I would check the main wiring harness, from the motor board to the console. Check the connection where the main frame connects inside the right upright bar. Remove the triangle shaped plastic cover bolt and side it up the upright bar. You will see the harness. Pull it through the acess hole the check the connection.Make sure all connections are tight.inclines motors rarely fail. To get it down you can reverse the red and black wires from the incline motor to the motor controller. Then run the calibration, once it's down just pull the safety key. It could be the display board or MCB
Dec 02, 2014 | Sole Fitness F63 Treadmill
I have a Gold's Gym Trainer 480. model ggtl39608. Everything was working fine. Now the incline will not work & the control panel will not light up.
This problem needs more details to service....seem like you have multiple problems...better to call for service 877-805-1030
Jan 01, 2014 | Golds Gym Exercise & Fitness
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
Proform EKG Cross Trainer Treadmill-will not operate since it has been moved. When the speed is set, it will start at the set speed and immediately decrease until it stops. Also, the incline will not...
check to see that the speed sensor did not move with the actual relocation of the machine. You may also need to recalibrate the machine so that it can figure out its own speed settings. With the incline not working also that can lead to a bad motor controller and these can go bad with too much moving of a machine - any bumps in the road can cause the electronics to short out if it has been previously used - grounding electricity out of components prior to moving prevents this from happening so that the stored electricity does not discharge with bumps in the road
Aug 04, 2010 | Proform CrossTrainer Treadmill
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Sounds like tire treads when at a very high speed
Check drive shaft rubbers at the cv joints
Jun 08, 2009 | 2004 Dodge Ram 2500
Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Mar 22, 2009 | Exercise & Fitness
Nautilus Tr300 Treadmill Logo
122 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
