Question about Samsung TV Remote Control
Direct TV remote will no control volume on Samsung ht-x50 surround sound system. The code I am using is 31868
VOTIT
  • 2071 Answers
SOURCE: Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 17, 2008
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
SOURCE: I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Posted on Nov 18, 2008
PC Commando
  • 142 Answers
SOURCE: what speakers can be plugged into a 46 inch
On the back of the TV there should be a variable audio out this will control the volume level on the speakers or at least it should
Posted on Oct 15, 2009
  • 1274 Answers
SOURCE: can't find the remote code for a samsung ht-d5610
Try 000,001,002,020.....hope this helps...
Posted on Apr 24, 2010
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
Jan 23, 2011 | Samsung HT-X50 System
The Directv codes for my Samsung HT-TZ512 surround sound/dvd player don't work. How can I program my Directv remote to control the dvd player? The codes I've tried are 20490, 20573, 20820, 21075 and 20899....
sometimes directv remotes do not work with surround dvd players. Try doing an automatic code search . Most of the time it will only allow you to power the dvd player and operate the volume.
Oct 23, 2009 | Samsung HT-TZ512T Theater System with...
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Samsung HT-Q100 System
No Surround Sound While Watching TV
You need a digital audio cable running back from your TV to the HT unit.
Feb 16, 2008 | Samsung HT-X50 System
Optimal Audio Settings for HT-X50
o factory 0 all way around ok cimnia sounds best also
Dec 26, 2007 | Samsung HT-X50 System
Dec 24, 2007 | Samsung HT-X50 System
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 05, 2007 | Samsung HT-X50 System
Samsung TV Remote Control Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
