Question about Sony Memory Stick PRO Duo (2GB) for PSP
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • 6,826 Answers
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot MY memory stick can be seen and read in my pc but - pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Posted on Aug 06, 2010
SOURCE:
My old memory stick says "cannot read memory stick, go to settings...etc...", so i took it to a technician and he advised me to buy a new one...so i bought a new 8gig memory stick but then the...
Make sure the contacts in the PSP's mem stick slot are clean... no dust/dirt in there. Format the memory stick on your PC then put it in the PSP. If the PC can read it and the PSP can't, you'll need to send in your PSP for repairs.
Jun 30, 2011 | Sony PlayStation Portable (PSP) Console
Memory stick error
FIRST U FORMATE U R MEMORY STICK FROM PSP THAN U SEE IN PC SOME FOLDERS U CAN COPY IN THAT FOLDERS ONLY THAN IT WILL RUN IN psp
Apr 25, 2010 | Sony PlayStation Portable (PSP) Console
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
My psp doesnt read the games inside my memory card
1. Does your PSP have a customized firmware (CFW) already?
2. If you just bought a new PSP, definitely it can not read the games inside the memory stick. You need to upgrade the original firmware of your PSP into customized firmware CFW.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
My memory stick duo, 4 gig cannot be open in my PSP
BECAUSE YOUR PSP DOESNT HAS PSP DATA RECOVERY GO TO THE PLASTATION PORTABLE SHOP WHATEVER AND SAY TO GUY MY PSP DOESNT HAS PSP DATA SO I CANOT PLAY PSP GAMES THEN IF IT IS FINISH MAKING DATA IN YOUR PSP GO THE SWITCH ON UR COMPUTER AND PLUG THE PSP WITH USB CONNECTER AND CREATE A FOLDER AND NAME IT ISO WHEN YOU FINISH COPY GAMES AND PASTE IT IN THE ISO FOLDER AND INJOY UR PLAYING GAMES THANK MY NAME IS ABDULAZIZ BIN NASSIR BIN JOUMA BIN MOHAMMED IAM FROM OMAN THANK U.
Sep 20, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
I try to upgrade with disc and with download from ps website
i think the awesomeness have need a high capacity of memory
i hope i can solve your problem
Aug 27, 2009 | Sony ACY-BR81/OB
PSP is unable to read a memory stick
you should get repair your PSP. Then check if your memory stick work. For sure, the problem is on the PSP.
Mar 29, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick duo won't read!
You probably need a new memory stick module inside the PSP. I have seen this many times in my store and we replaced the board and it worked fine. Contact your local game stores to see if they do console repairs. See if there is a Play-N-Trade within your area. I work at one and we do repairs. I'm not sure if Gamestop or Gamecrazy do repairs.
Feb 19, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont read the memory stick
Format the memory-stick As FAT In Windows ( On A PC )
Then re-format The Memory stick in Your PSP.
This Should Solve Your Problem.
Mike @ Compurepair.
Feb 24, 2008 | Sony PlayStation Portable (PSP) Console
PC doesnt recongize my memory stick as a formatted memory stick...
Do both systems run XP? Also, check the driver files on your PC, and test it with another card of the same make. Is the write-protection switch set to on? Test the card reader with other formats of cards, if it is a multiple reader, just to make sure that it is functioning at all.
Jun 04, 2007 | Sony PlayStation Portable (PSP) Console
Sony Memory Stick PRO Duo (2GB) for PSP Logo
239 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
