Question about JVC RX-6008V Receiver
Have JVC 6008V A/V Receiver. No out-put from left-front speaker out terminals. Checked fuses, and all are good. R/F, and all other speaker out functions work fine.Switched speakers to make sure problem was not in the speakers, or wires. Bought used. Any answers??
Make sure you're using the corresponding speaker inputs for speaker 1 (only) and turn off Speaker 2 on the bottom left corner near the headphone jack (it should be sticking out further then the speaker 1 button). hope this helps.
Posted on Nov 28, 2010
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
Apr 11, 2010 | JVC KD-G200 CD Player
The screen says overload
disconnect all your speakers and if it still does it, the unit is bad. if not, then youve got a bad speaker. connect them 1 at a time til you find it. good luck
Feb 10, 2010 | JVC RX-6008V Receiver
Overload comes on after start up
disconnect all speakers to see if 'overload' goes away.if it goes away then you might have a bad speaker.If OVERLOAD is still there with no speakers connected .Then audio output circuit needs repair in unit..
Jul 30, 2009 | JVC RX-6008V Receiver
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Reciever Problem
hi, its definetly an internal problem, commonly in the output section, usually its a capacitor or an transistor which is leaky or short. which causes the overload, so u will need a techinical hand to get it resolved.
Feb 12, 2008 | Audio Players & Recorders
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Nov 29, 2007 | JVC RX-884V Receiver
JVC RX-6008v faceplate
have a jvc home theater with this next problem, when I turn the display lights up then see the name overload and shuts down the display, and it does not connect the speakers
Sep 27, 2006 | JVC RX-6008V Receiver
JVC RX-6008V Receiver Logo
303 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
