Question about Toro Lawn Mower With Toro Power Tools
After changing spark plug lawn mower sounds like its missing
2 Suggested Answers
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
Where is the spark plug
Where is the spark plug In the cylinder head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Tips Replace Lawn Mower Spark Plug
How to Change Push Mower Spark Plug
How To Change Spark Plug on John Deere LA 105 Lawn Tractor or Riding Mower
How to change spark plug on craftsman LT1000
Mar 27, 2016 | Garden
How do i change a spark plug on Craftsman lawn mower
Mine takes a three quarter socket and disconnect the spark plug wire take the old one out and install a new one. Putting the wire back on after putting in the plug.To do it right check the spark plug gap but usually it is factory set anyway.
Jun 30, 2014 | Craftsman Garden
Lawn mower miss firing changed the spark plug. When started it's making a punting sound. What would be the solution?
Did you hit something with your mower? It sounds like a timing problem. The shear key may be dented throughing off your timing. The shear key is located between the flywheel and the top of the crankshaft. Remove the top cover to your engine and any attachments. Remove the flywheel. Check the key, I believe you will find your problem, a deformed shear key. Get a new one, replace all parts,and you should be ready to go. GOOD LUCK.
Jun 29, 2011 | Yard Machines Garden
Was cutting grassstopped for maybe three minuts then tried to start mower but it wouldnt . Refueld and a new plug got nothing but tired of pulling any suggestions
check for spark...if the mower runs for three minutes it might be failing because it looses spark as soon as the ignition module heats up.
If your mower cuts out and the spark check indicate no spark then you know you need a new module. While you are changing the module you can check for animal nesting in the cooling fins under the motor cover.
Its usually how lawn mower ignitions get baked in the first place. You cant see it from the outside....so you cant fault yourself for missing it.
good luck and be careful!
Jun 26, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
How to change a spark plug on a club cadett model # 959435
Hello. Changing the spark plug requires a couple of tools, all available at any auto parts store, and the right replacement plug. Regarding the plug, look in the manual or take the old plug to the auto parts store and have the clerk cross reference for you to be sure you get the same one or a comparable. Look at the links below to learn more about changing spark plugs in lawn mowers than most people know. Have fun with it.
Here is the link to a video to show you the steps. http://www.ehow.com/video_4426873_changing-spark-plugs-lawn-mower.html
http://www.oneprojectcloser.com/how-to-change-spark-plug-in-a-lawnmower-example-briggs-stratton-engines-in-craftsman-and-murray-mowers/
Apr 16, 2010 | Poulan "" Push Mower
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Where is the spark plug?
Look at the front of the mower...the spark plug is right there. You can't miss it, there is a wire attached to it, that is the spark plug wire...take it off and voila, the spark plug.
Oct 29, 2009 | Mtd 22" Yard Machine Push Mower
Mower misses out, runs out of gas quick and backfires
sounds like a timing issue. check to see if the sheer key is damaged under the flywheel.
May 22, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
170 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
