Question about Craftsman 4" Drill Press Vise, Side - Plate Angle
The bolt is bent and needs ti be replaced. Can i buy a new bold
  • 245 Answers
Hi
You can buy a replacement at any decent hardware store like ACE,even HomeDepot or Lowes.Take whatever you have with you and remember that it's almost certain to be a metric screw.Sears stopped buying American decades ago.
If this helps,would you rate my post?
Bob
Posted on Aug 20, 2010
Replacing front wheel bearing
Buy the new bearing. Take the wheel off. Then you will have to take the break caliper off there are two bolts in the back of it pull it off and move it to the side. Pull the break rotter off. The you will see the old bearing. Take the large bold on the drive shaft off its right in the middle of the bearing. Take the bolts that hold the bearing on there will be three or four. Pull it straight off. Then put the new one in its place. Make sure everything is good and tight. The big nut on the drive shaft wont need to be super tight. Ask when you you buy the new bearing what the torque should be. If you don't have a torque wrench it should be tight but not super tight if you know what I mean. Hope that helps
here is a video of how to do it
https://www.youtube.com/watch?v=6HuGqAiGowk
Jul 19, 2018 | Honda Cars & Trucks
What size of bolts hold on the engine mounts
Take out one of the other mount bolts for a sample
You don't know how to measure bolt threads & convert
to metric if necessary?
That is a must if your going to work on any vehicle from
1980 on
Jan 22, 2013 | 1996 Dodge Caravan
Replace main spring in RWS
hello friends you broke my rifle spring my rifle crosman optimus ea .177 cal. and the dealer put a new one, but it has presicion not know if I should wait for 500 shots or more like new or will be another problem, thanks for your help
Oct 08, 2012 | RWS Diana 34P air rifle - 0.177 Caliber
Front sprocket is bent - needs to be replaced. I am trying to find where I can purchase a new sprocket for a Huff Uproar 20" bike
Any Bike Shop. Or assess the number of teeth, number of bolts and the bolt pattern yourself and search the web for one that matches.
"how to measure chainring bolt pattern"
also check out "fix bent chainring"
Aug 06, 2011 | Cycling
Can i replace the cracked screen on my ti-89 titanium or do i have to buy a new calculator
Well, of course you can replace it, but it would probably be more productive to buy a new one due to the time it takes to replace it and it's individual cost, not to mention it wouldn't be easy to find.
Mar 03, 2011 | Texas Instruments TI-89 Calculator
Wen fittin injectors in a vw pd engine wa settings is there
with out the correct aligining tools from vw you will need to measure from the side of the injector where the wedge slots in to the front part of the cam carrier molding in the head to use to re aligin the new unit the wedge bold is torqued to 20nm ( replace this bolt ) and the injector followers are torques to 20nm and 90 degrees the cam cover bolts are set to 20 nm
Apr 27, 2010 | 2001 Volkswagen new Passat
Bent valves 2000 Ford Escort ZX2
a couple bent valves shouldnt be more then a few hundred dollars to have replacedand can be fixed yes, but also the vehicle has to have another timing chain ooput on and be retimed this will probably be a total cost of somewhere in the $800 dollar range (this is only an estimate!!) to replace your entire engine would cost substantially more and in all realit i would try to sell the opother vehicle for parts, trade in, or as a whole and buy another vehicle before i invested the money into a new engine for this particular car
Sep 05, 2009 | 2000 Ford Escort
Alternator need to be replace
under the hood find the alternator, then on the alternator there a bolt on the side that is long you have to loosen it last after u loosen the bolts that are holding the alt then the long bold last it loosens the belts ,take the belts of then but new one one and but the bolts that hold the alt on first dont tighten them then the big bolt make it tight how u need not to tight and then tighten the bolts that hold the alt tigher,if my info was of any help to you please leave a comment,thank you.
Sep 03, 2009 | 1998 Lincoln Town Car
Left front sway bar has lost the lower bolt. Replace bolt & rubber or the whole thing?
You can buy a kit with everything you need from any auto parts store. If you mean replace the sway bar its self no you do not, unless its broke or bent.
Apr 15, 2009 | 2000 Ford Ranger SuperCab
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
Craftsman 4" Drill Press Vise, Side - Plate Angle Logo
37 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Gary Nitowski
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
