Guitar amplifier wont turn on - Audio Players & Recorders
  • Anonymous Apr 25, 2009
    I too am having the exact same problem :( It makes like a faint noise, but i noticed the light doesn't come on and yea it doesn't work :(
Check fuse and switch
Posted on Apr 27, 2008
My amp, was working fine last night, it wont turn on, and i tried switching guitar, cables, even power supplys and still wont turn on, i heard a pop last time i used my amp, and then the signal was lost...
The unit will require repair and if you are not adept at electronics, you will need to take it to a shop. Likely there is failure in the power supply or amplifier that has blown the fuse. Replacing the fuse WITHOUT repairing the cause MAY do additional damage.
Dec 28, 2010 | Fender Hot Rod Deluxe Guitar Combo...
When I turn on the amp it turns on, but it doesn't amplify my guitar/ work at all.
Check the power transformer first to see if tou are getting power to the amplifier section. If you are getting power, your problem is probably the power transist is bad.
Oct 04, 2010 | Pyramid GA610 600 Watts Dual Channel...
When turn on the amplifier without guitar and with guitar, it sounds really loud and earing senstation is horrible it seems like the speaker will go to explote it is a strange bad sound
That could be a number of problems, without looking at it its hard to diagnose.
The best solution would be to take it in to a local music store or repair specialist because unless you are a trained professional, working with guitar amplifiers can be dangerous.
Feb 07, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Guitar Problem I Think.
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
Nov 04, 2008 | Washburn Amplifiers: 25 WATT Guitar...
When I turn the power on on my Peavey blazer 158 guitar amp nothing happens. Is there a fuse?
Hi I have written two troubleshooting guides on the issues you have try them at http://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
Let me know if you still face a problem
Oct 13, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Problem with pickup on guitar washburn d46
Hello woizo,
The windings of the pickup might be bad. Basically these are magnetic pickups that take the string vibrations and by using transducers converts the vibrations into electrical energy and the by using preamplifier's and finally a main amplifier it takes the electrical energy and then turns it into sound. It sounds like in your case the pickups need to be repaired or replaced.
Now I would check the amplifier first and the run a test on the output of the guitar to make sure the potentiometers (volume, tone, etc) are ok. If these are ok then I would really suspect the pickups.
I hope this helps,
Thank you,
Shuttle83
Apr 13, 2008 | Car Audio & Video
Guitar/amplifier 'buzz'
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Dec 27, 2007 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
323 people viewed this question
 Grubhead
Grubhead
