Question about Nautica N22503 (Size: ) Watch for Men
Nautica N22503 Watch for Men the red second hand does not reset at 12o'clock position.. the 30mins (top left dial) also resets else where.. and so does the 12hourly hand (bottom dial).
escapement
  • 2334 Answers
SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
Posted on Mar 22, 2009
escapement
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
OhioTrucker
  • 33 Answers
SOURCE: watch hour and minute hands are not lined up at 12 o'clock
Take the back off, then slip the works out of the case. move the hands to line up at 12.. hope this helps..
Posted on Feb 27, 2010
escapement
  • 2334 Answers
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Posted on Mar 04, 2010
Testimonial: "excellent work ! thanks a lot !"
Nautica replacement band for model A37003L
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Mar 01, 2014 | Nautica Nsr 01 Black Dial with Red Rubber...
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Jan 02, 2014 | Watches
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
Can I reset the second hand and the lower dial on the watch?
long answer with info given, but this is what will explain it all that small subdial at the 6 area is the second hand that runs at all times, large red hand is stop watch seconds,allso on the center pin is the minute hand for stopwatch 2 o,clock subdial is tenths of a second, for stop watch 10 o,clock subdial is hours for stop watch
Jul 09, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Need instructions to reset sub dials on Nautica Chronograph watch
Mar 20, 2009 | Nautica Blue Dail Yacht Chronograph Watch...
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Luminox 8152 chrono
If new, just take back and exchange it for another working one.
Sep 20, 2017 | Luminox Navy Seal Divers #8352 Watch for...
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Nautica N22503 (Size: ) Watch for Men Logo
139 people viewed this question
Top Nautica Watches Experts
Jerry Greenberg
Jerry Greenberg
Are you a Nautica Watch Expert? Answer questions, earn points and help others
