Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the termister/heater is out.
Your repair Manual with photos and tech data
HEREI will leave that on there for a while but it takes up broadband so print that manual out and keep it close to that washer.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I am experiencing similar problem, I checked pump filter and was clogged, removed and tried again and same problem found water leaking from soap dispenser. I am not sure where to locate the codes given in the manual and how or where to read it on the washing machine model WM2277HB. Please advise if you have any information.
