My three year old stood on the door of my Hotpoint Aquarius 1000 and snapped it off! I've got a new hinge for it, have unscrewed the old one not realising that there was a bracket that the screws screwed into on the inside! This has fallen inside the machine, does anybody know how I can get inside the machine to get it out? Thanks..
  • Washing Mach... Master
  • 3,463 Answers
Just tilt the washer backwards, and you should be able to locate the hinge bracket on the left hand side at the bottom.
Posted on Aug 06, 2010
Hi, I have a Hotpoint Aquarius F545 washing machine, the door handle has snapped off, so I cant open it. Ive order my new one and its easy to fit, but I have no idea how to open the washer door without...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa
Mar 02, 2011 | Hotpoint Aquarius WF000 Front Load Washer
No power to hotpoint aquarious 1000 after changing door hinge
First check the wall outlet has the correct voltage supply, if it is having the proper voltage.
It sounds like when you changed the door hinge on the door lock system is getting failed, and it damages the timer. Since the timer is damaged there is no power available to the washer.
Other possibilities are the failure is either the control board, power cord or a loose or bad connection between the power cord and the control board.
However, you need technician's help to diagnosis the problem related to controlling board.
Hope this helps.
Shane
Feb 12, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Plate at back of door hinge on hotpoint aqarius has fallen down
Tilt the washer back, and you will be able to retrieve the back plate from the bottom of the washer.
To refit it, you will have remove the front of the door seal from the cabinet front.
May 25, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Thanks
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Snapped door lock on hotpoint washer/dryer
What you need is a new door latch assy. To fit, remove all screws that hold the 2 halves of the door together, and prize the 2 halves apart, be careful the door glass does not fall to the floor and break.
Fit the new door latch, and reassemble door.
That should solve your problem.
The part is relatively inexpensive.
If you can;t obtain the part locally,then try:
www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
How to get access to door interlock mechanism?
WHAT YOU HAVE TODO TO GET THE FRONT OFF IS TAKE OUT THE SOAP DRAWER COMPLETELY THERE IS FOUR PHILLIPS SCEWS TAKE THEM ALL OUT THAN TAKE THE TWO KNOBS OFF THAN LIFT UP THE PANEL SLOWLY WATCH THE WIRES THAN UNSCREW THE THREE SCREWS ACCROSS THE TOP OF THE FRONT PANEL AND THE THREE ALONG THE BOTTOM YOU SHOULD NOT HAVE TO TAKE OFF THE RUBBER TO GAIN TO THE DOOR SWITCH
Apr 20, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
