Question about Proform 760 CrossTrainer Treadmill
I just moved my treadmill from the garage into the house and it has no power when plugged in. It hasn't been used in a couple of years. Does it have a reset button? What do I do?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Yes there is a reset by the power cord
Posted on Aug 12, 2010
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Pacemaster treadmill no power
http://www.youtube.com/watch?v=N6Yg5S0WML8
see the step for torubleshooting your problem.
Of course test the breaker or fuse from your house. See if the wire ground is connected to your outlet supply. Do not use any extension cord.Use regulator voltage recommended.
If necesary call some electrician .
sincerely.
Dec 22, 2011 | Exercise & Fitness
9.21 and house circuit
You have strong short circuit in your treadmill machine.Please check the videos carefully using the Dvom instructions attached.
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Test the power cord+some cable making ground+finally the main motor (shorted or grounding) +Transformer(shorter+grounding).Repair using the Dvom
Nov 12, 2011 | Precor 9.21 Treadmill
Treadmill will not come on
Watch this videos:
You must check the fuses+breaker inside from machine +breaker from house, of course check power cord if there are some loose cable, or another loose cable inside from the machine, or broken cable. Tight any cable inside.!
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
Oct 29, 2011 | Exercise & Fitness
After walking for 10 minutes or so, or even sooner when I am jogging, the 921 loses power and trip my house circuit breaker. What needs to be replaced? Guessing it is the power cord as the 921 is 20...
Check your Amps on the circuit that is being tripped. The treadmill needs 15 Amps to run. If you have a 15 Amp circuit that is running the treadmill and other electronics (or lights), the circuit will trip. You may need to replace the circuit with more Amps.
Mar 02, 2011 | Precor 9.21 Treadmill
Lifestrider 3325 will not turn on.
Keep unit unplug check your outlet if power is good then plug unit in make sure your safety is engaged if that does not work, open motor shroud and under that shroud their should be a paper with a wiring diagram and with a Ohm meter check where you have a open circuit.
May 05, 2010 | Exercise & Fitness
Treadmill won't turn on after not being used for 6 months
the only on/off switch on that model is located beside the power cord where it enters the lower body area.
Nov 12, 2009 | Exercise & Fitness
Proform 760 CrossTrainer Treadmill Logo
204 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
