Question about Canon imageRUNNER 400S Copier
How to solve 2side paper jam its in continue but 1 side is working good...how to solve this problem? its ir 400 canon machine
  • 1,219 Answers
open the front cover and clean the duplex rollers with alcohol and dry it.
Also, if you have stand for these copier, on the left side of the stand there is opening on top of stand where the copy is going when it copy second side, check for any opsticles in there.
Hope that helped
Posted on Aug 09, 2010
I have cannon ir 3300 image runner it shows paper jammed in right side but there is no paper jammed in any side of the machine
Manoj, Try using compressed air to blow dust and debris out of printer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix paper jam Canon iR3300 printer
Home Canon Italia
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-3300
Aug 20, 2016 | Canon Ir 3300 Black & White Copier
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
Ir 33o double side printing problem
Depending where the paper is getting jammed at, take of all rubber pads off the right door. Several places like on each side of the guides. I can think of six pads that need to be removed. They are black and about 1/4 inch wide. Sometime they get sticky and cause the guides in the duplex area to not function correctly.
Sep 01, 2014 | Canon iR330-400 PS Ver 1.0
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
115 people viewed this question
old marine
old marine
