Question about HP Pavilion dv6000z Notebook
My hp dv6000 was working fine 3 weeks ago. When I came back to it one night it was shut off after being but on sleep. I turn it on and the it seems as though it doesn't have enough power to power up. the battery and charger are all fine. I think it has something to do with a battery on the motherboard or the power supply. But i still need help
    Problem Solver:
  • 5 Answers
Hi, If you are you swift with a phillips screwdriver and a pen torch, you can get a how to on the net for this repair. I just did it and what an amazing fix. Otherwise, you can send it out and have it repaired for $125 Replacement mother boards are OEM and have not been modded for reduced heat dissipation and will fail just like the original did. Just to get mine up for a few minutes, I blew compressed air into fan heatsink area and a ton of ghost farts flew out and the fan spun up long enough to identify my issue. The GPU (graphics processing unit) had become overheated and connections to the main board were lost. I disassembled and laced heat shields around the GPU chip and remelted the solder connections, about 235 F for 40 55 seconds. Reassembled and iT WORKED! Took a little guts to just try, why not it was already broke?! Otherwise $125 ain't as much as the dang thing was when first purchased. Go ahead, research it, dig in an head first - you can if you think so. <!-- from fixya rte -->
Posted on Aug 15, 2010
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 349 Answers
It sounds like the Power Jack where the adapter plugs in.
Posted on Aug 06, 2010
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
Stand by time is flashing tv will not start
no the tv has no battery for memory.the memory is supplied by the 5 volt standby.the tv must be plugged in to maintain the 5 volts to keep its memory.
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Hp dv6000 laptop won't turn on!
this sounds like a common problem with a poor design of the motherboard and the nvidia chip. check this link you may still fall in the dates for hp to fix it for free. god luck http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Jun 14, 2009 | HP Computers & Internet
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
Pavilion dv6000t screen won't come on.
I had this exact problem with a customers computer andi found out that HP put faulty motherboards in the DV6000, DV9000, Compaq V6000 Series Computers. Thankfully HP fixing all computers for free and extending the warranty even if the warranty has expired they will ship you a box and you ship it off and they fix it at no cost. the turn around period is about 7 days.
Here is a link to an article that talks about it
http://mattsblog.ca/2007/12/14/having-problems-with-your-hp-pavilion-dv6000-dv9000-or-presario-v6000-series-notebook/
Hope this helps!
NosirromNet
Dec 14, 2008 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP Pavilion dv6000z Notebook Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
