I have Compaq Presario CQ42 118TU. The F1 to F12 keys are no longer the upper layer (used to be default). The HP quick launch buttons are now the default upper layer. Now i have to press the 'fn' key first before i can get to the F1-F12 keys instead of the other way around. How do I change the keyboard to the old way that i'm so used to?????
I just had exactly the same issue. I found the answer on the HP website, but to save you looking for it, here's what you do:
1) Go to the BIOS for your machine. You'll do this by interrupting the startup sequence. On my Presario CQ42, I had to press ESC while the machine was starting.
2) Once in the BIOS, use the right/left arrow keys to move to the System Configuration tab.
3) Use the up/down arrow keys to move to the Action Key setting (Enable/Disable) and change it from the current setting.
4) Save and exit the BIOS.
Once your laptop finishes the boot-up, the F1-F12 keys should function the way you were used to.
Posted on Aug 09, 2010
  • chiragkrish Sep 16, 2010
    ya its right...!!
    thanks to you...!!
    i am facing very problem for this matter.
How to use F1 - F12 on a compaq presario cq57
Try holding down the "Fn" key. Should be on bottom right
Jan 14, 2014 | Compaq Computers & Internet
I don't have the Quick Reference Guide for my Compaq Presario F756NR (may never have had it). I cannot figure out way each of the function buttons (F1 to F10) are supposed to do. And what is the f
Fn button is your Function button, you hold it down and it allows you to use the hotkeys that are usually colour coded the same as the Fn lettering. Stuff like brightness/contrast volume up and down. That kinda thing.
Jun 24, 2012 | HP Compaq Presario F756NR Notebook
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
In my laptop key from f1 to f12 is not working my compaq modle is presario cq56
You have to find "fn" key on keypad of your laptop. When you want to use function keys, you need to press and hold the "fn" key.
Jul 28, 2011 | Compaq Presario CQ56-115DX Laptop
HOW THE FN+F1,F2,F3,F4,F5,F6,F7,F8,F9,F10,F11&F12 WORKS???????
FN+ F buttons are used as a shortcut. For example, in my laptop, F1 button has a ? icone at the bottom. when a pres Fn+F1, it will launch the help program. F1 to F12 buttons have different shortcuts.
Apr 29, 2011 | HEWLETT-PACKARD Hp G62-225dx Laptop...
I have a Compaq Presario CQ56-204CA. The default F keys are functions like brightness and stuff. To reach a F key, i must hold the Fn key. I would like to switch that to the default keys is the F keys....
I had the same problem and it looks like you can change this setting within the BIOS. It's called Action Keys, and apparently HP thought its users would rather press Fn to use F1-F12 than pressing Fn to change the brightness and such. Here's an HP article I used to change this on a Presario CQ56-115DX. Just use the directions and disable Action Keys
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02035108&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 15, 2011 | Computers & Internet
Set up bios hp compaq presario v2000
1. restart you computer and enter bios screen by pressing f1 or f10 at first screen
2. set bios as you like, or press f5 tkey to load the default bios configuration
3. select yes using arrow key, and then press enter
4. press the f10 key to save the setting and exit
5. select yes using arrow keys and press enter
for more isformation about hp compaq bios see this page
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=409741&prodTypeId=12454&objectID=c00220813
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | HP Compaq Presario V2000 Notebook
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
How to restore The Compaq Presario SR1720NX to factory defaults
When you start the computer it will breifly display a button to press to enter recovery console, usualy F11 or F12 press that button and you should be able to restore it.
May 20, 2009 | Compaq Computers & Internet
Quick launch button on compaqv3777tu
download the software that's compatible to Vista try this link.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3671001&lang=en#
Jan 21, 2009 | Compaq Presario Notebook
Computers & Internet Logo
2,164 people viewed this question
Alun Cox
David Payne
David Payne
