Question about E-Machines eMachines Desktop PC
Desktop T2984 all blue screen stop 0X0000008E WIN 32K sys address Bf82EF60 base at Bf800000 it says check for driver uipdates or change video adapters or check for BIOS updates or disable BIOS memory options??????? Help
  • lindaa_kelly Aug 06, 2010
    how do I replace the RAM?
  • 4,281 Answers
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Posted on Aug 06, 2010
  • Try with another RAM.
    For that open back cover of cpu cabinet .
    Then you can see mtherboard chip set there is RAM memory fixed on motherboard change it with another 1.
    If there is 2 RAM try with 1 RAM 1 by 1 then check.
    If any RAM memory is corrupt it cause this blue screen of death error too.
    Let me know if you need further assistance.
    Genius:
  • 1,478 Answers
The problem with blue screen on your system is related two major problem, one, is either the operating system on your system is corrupt and will need to be repaired, insert the operating system cd and select repair, this will help fix the problem of the blue screen on your system.
The second major problem is the the memory stick on your system, it might be bad, this are the major cause of any blue screen on system. I will advice you first repair the operating system, if that did not solve the problem, replace the RAM, it is bad.
Take care.
  • Jimoh Adeleke Muyideen Aug 06, 2010
    The RAM is inside the system unit, on the mother board, you will need to get another RAM to replace the one on the board of your system. If you lose the screws by the side of the system unit, you will have access to the mother board, on the mother board, you will see the memory stick on the board, unclip to remove it and replace, once this done, it will fix the problem.
Here's one info i copied down: Win32k.sys - Address BF87743A base at BF800000
That blue screen error is normally a bad driver. Windows could have updated a device in your pc and it just not work. Go into safe mode and roll the pc back to a date before the blue screen.
Apr 19, 2014 | Acer Computers & Internet
I have a blue screen ,then when i restart it will be normal ,but after a while blue screen again : stop:0x0000008e(0xc0000005,0xBA5383c9,0xB8FE282C,0x000000) sysaudio.sys-Address BA5383c9 based at...
this is a general error and this might be because of the operating system that is somehow corrupted. another thing is memory (RAM) of your computer is malfunctioned.
try to run memory test. if the memory looks OK then back up your files and reformat your computer
Sep 07, 2011 | Evesham Evolution PC Desktop
Hi, When I start run that GA-8IPE1000, it runs a second and turn off automatically. And I hit it again and again, it runs correctly but when I install WINDOWS XP SPII, it stops itself installation and...
Hi, you can download a manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=1863#dl
My guess is that your have a failure in:
The hardrive because you get a blue screen
its a typical problem when windows not loading normaly
could be a bad sectors on the drive.
The ram
Or the cpu due to maybe over heating
Or the mainboad is simply have a defect.
Aug 25, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Regards
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Blue Screen
This is your computer emmory related issue.
RAm emory or harddisk.
If you have desk top rewfix RAM memory then boot your computer with winxp recovery or bootable disk.
For that when you power up the computer press F1 or F2 or "del" key for enter in bios then go to boot optiojn and set frist boot device as your cd or dvd rom then save and exit from bios.
Then put that disk in rom then it boot with it.
then press "y" then it fix error on harddisk.
Then check then if stillsame issue then choose repair option and repair your os.
let me know if you need more assistanse.
Thanks.
Sep 24, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
C6180 crashes my XP blue screen error msg 0X0000008E (OXC0000005 0XA56AC758,0XB1cc3230,OX00000000 kmixer.sys-address A56AC758 base at A5693000 dateStamp 480254b3
Try these steps given in the below links and check if it resolves the issue.
Link 1:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00273360&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Link 2:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093821&tmp_track_link=ot_recdoc/c00273360/en_us/c00093821/loc:1&lc=en&dlc=en&cc=us
Wish
Aug 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
XP Home Edition crashes while in standby - blue screen error
Sounds like a bad file . I would consider reinstalling windows. When it starts up, for a new install, it will find your existing OS and ask it you want it repaired, say yes then it wil repair it and leave al you data as is.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Bsod during windows installation
Try doing this as suugested, you might not need reformatting.
http://www.pcreview.co.uk/forums/thread-94921.php
Oct 22, 2008 | Gateway M350 Notebook
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
