Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
I cannot get the TV to turn on by using the side controls. I briefly get a box saying no channels are available. I originally just had sound, now no picture. Called Charter cable. They came and said it is the TV remote issue or the TV. THis TV is only two years old. Got it from Target. What is your opinion?
  • 11,361 Answers
Common issue with this TV is the cold solder joints in the power supply module, please see my album of this model at Photobucket.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Harmony 1000 never worked right; out of warranty
email in they will help you there. I have never been turned down by them! i have been out of warranty for about a year
May 29, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
I am trying to connect the vcr to the tv with a cable box
There are two ways to connect your equipment.
1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
Mar 30, 2009 | Hitachi Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
54 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
