Question about Whirlpool GS5SHAXN Side by Side Refrigerator
I have a Whirlpool GS6HEXNL00. The light in our refrigerator went out. At the same time we lost the lights that tells what the freezer temp (1-9) is set at and the refirg temp. It is also making a clicking noise. The Freezer portion seems to be working fine. I think we could figure out how to change the light bulb the temp indicator and the clicking is concerning. Suggestions as to what's wrong and how to fix it?
    Brigadier General:
  • 3,513 Answers
Hi
The clicking is from the main control board relays that is clicking off and on . OR your main-board/motherboard is bad. you need to replace it.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 06, 2010
Whirlpool High Temperature Alarm Keeps Blinking
New Refrigerator / Freezer usually takes up to 12 hours to get the food down to temp and the inside air temps to stabilize...
Now, try explaining that to a BSN who is required to take hourly temp readings on a refrigerator and just loaded it half full of warm soft drinks and is opening and closing the door repeatedly retrieving supplies.
You lower the temp to "suit" (shut 'er up) and tomorrow they're calling you back because it's too cold...
Apr 13, 2014 | Whirlpool Refrigerators
Whirlpool gs6heXnl00
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool a class freezer
Red Light : Alarm high temperature.
Amber Light : Fast freeze function (ie ignores thermostat and keeps unit freezing all the time).
Green light: mains power.
If you have lost temperature on a freezer it is usually a major fault either the compressor has failed or you have lost charge (possibly the start relay). If you are able to get to the rear of the unit and check the compressor, if it is hot then it is more likely a major fault. A good fridge guy can normally tell the problem within a short time of inspecting the unit. Sorry to not sound hopeful. Good luck.
Mar 13, 2008 | Refrigerators
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
PSC 23 SGRD Not working
1. Can anyone tell me the length of warranty on the PSC 23 GRD SS refrigerator? Purchased in 2006.
2. Water and ice despenser light is on but not working.
3. Both refigerator and freezer temps not working.
Please advise on solution to problems. Thanks.
Sep 09, 2007 | GE PSC23SGR Stainless Steel Side by Side...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
