Question about Panasonic Lands Phones
How can I set the clock and date of the panasonic KX-T2375MX model?
Please follow the procedure in the below.
1) Press 'PROGRAM' button
2) Press 'MUTE' button
3) Press '6' button
4) Enter the current time using a four-digit number(ex, 0930 for 09:30)
5) Press '#' to select AM, PM or 24-hour clock. (Each time you press '#', the selection will change sequentially)
5) Press 'PROGRAM' button (A long beep sounds when completed)
I hope this will be helpful for you.
Thanks.
Posted on Sep 14, 2009
  • modemail Nov 23, 2010
    thank you very much sir..
Which is the most recent phone Panasonic KX-TGA807E or Panasonic KX-TCA122E
It looks like the KX-TGA807E is the newer model. The manual for the Panasonic KX-TGA807E has a copyright date of 2007. The manual for the KX-TCA122E has a copyright date of 2005.
I hope this helps.
Jun 17, 2016 | Panasonic Lands Phones
How do I reset my date & time for Panasonic kxtga470
The KX-TGA470 handset works with several models of Panasonic cordless phone base units. Press Menu and then press #. Next press 1 0 1 . (Alternatively use the arrow keys to navigate to find Initial Settings and then Set date and time after pressing Menu.) If you need to change the date, type in the date as three sets of two digit numbers (month, day and year). Then press OK. Next type in the time. Press OK and then select AM/PM with the arrow keys if you are using 12-hour time. Finally chose Save followed by Off.
The manual for the base describes setting the date and time. See http://panasonic.ca/viewing/ALL/KX-TG4711C/OI/TG4711C_PNQX5094ZA/TG4711C_PNQX5094ZA.pdf on page 15.
I hope this helps.
Nov 03, 2014 | Lands Phones
How can i set the date n time in Panasonic TX-TGA542AL cordless phone?
This is how to set date and time on panasonic KX-TGA542AL.
Press the "Menu" key.
Use the up and down arrow keys to select "Date and time." Press "OK."
Enter the month, date and year using two digits for each on the keypad.
Enter the hour and minute in 12-hour clock format using the keypad.
Press the asterisk (*) key to toggle between "AM" and "PM."
Press "OK" and then "OFF."
Regards
Jul 12, 2011 | Panasonic KX-TGA560 Cordless Expansion...
How to set the clock at a panasonic kx-t7730
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Mar 27, 2010 | Panasonic KX-T7730 Corded Phone
Change the time on the clock
For the KSU model TDA50, TDA100/200, TDE or NCP.
From the main phone or manager phone default ext. 101 enter prog, *#1234. Then dial program code 000, select enter, Use the up down pad to move the cursor enter your time and date select enter when finished. Then Exit on the screen .
Jul 28, 2009 | Panasonic KX-T7633 Corded Phone
How do you set the time?
just go to the settings.. then phone settings.. then clock/date and date settings.. after taht you can set the time..Gb
Jul 15, 2009 | Panasonic KX TC1503 Cordless Phone
My clock is wrong on my Panasonic KX-TG2650N phone.. How do I fix
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
Dec 27, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
915 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
