Question about Cakewalk SONAR Home Studio 7 XL for PC
Unable to open audio playback device. Device may not support the current project's audio format in use
USB containing MP3's is inserted but deck says "unsupported" and will not display songs. I transferred songs on an IMac to the USB if that matters.
Using an unsupported USB device can result in abnormal playback or display of the audio file. Even if you use the USB device conforming to the above specs, audio files cannot be played normally depending on the type or condition of the USB device.
Feb 21, 2016 | Alpine CDE-143BT Advanced Bluetooth CD...
No playback through my headphones
Hi, You will need to follow a process of elimination, that way you can isolate problem. first thing you should do is turn every thing off and on. Hopefully windows sorts it all out for you.
If that don't work, plug headphones into a different Jack/usb port.
If that works, it means that you can now isolate problem to your sound card. Next step I would take is make sure sound card is seated in pci slot correctly. Nice and tight. Make sure you have used screw, this will ensure you have good Ground. If you still have no luck. Go to device manager, look for your card. If your card shows up in device manager, click on it to open up different drivers for it. By Right clicking on your card you can have the option to delete / Uninstall driver. Uninstall all the drivers for your card and restart computer. Windows will think It's new hardware and will reinstall drivers. I reckon this will work. The only other thing I can think of is to bring up playback devices on your system tray and make sure that it is actually set to playback on the device of your choice.
That should give you something to do for a while. Good luck.
Oct 24, 2017 | Tascam US-122 USB Audio/MIDI Interface...
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
Cano't change from speaker 2 earphones. volume on speaker alltime
It is a conflict of drivers in some PC's.
First make the sound device to speaker as default.
1. Click Start, type Sound in the Start Search box.
4. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
5. In the Playback tab if you are unable to find the Speakers then please right click on any of the devices under playback tab and select Show disconnected devices and Show Disabled devices.
6. Select Speakers, and then click Set Default. (If you find Conexant or anything similar to that click on it and select Set Default)
7. Click OK to save your settings and to close the Sound dialog box.
If speaker is set as default, then re-install drivers.
Uninstall the Sound device:
1.Click Start, and in start search type device manager and press enter.
2.Expand sound,video and game controllers, and right-click on the Sound driver and choose uninstall.
3.Check the option for delete the device software for this device.
4.Now restart the computer and boot into normal mode.
Now, uninstall the programs and features:
1.Click Start, and in Start search type programs and features.
2.Choose the audio application and click on Uninstall.
3.Restart the computer.
Upon restart, install the audio driver from the disc which is given by manufacturer of the computer.
Please let me know if this works.
Regards,
Nags
Jan 27, 2010 | Computers & Internet
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
Dec 27, 2009 | Computers & Internet
Just installed new motherboard and now receive following message......itunes has detected a problem with your audio configuration. Audio/Video playback may not operate properly. How do I fix this?
Try reinstalling quicktime. Go on control panel uninstall quicktime. Then go to this url:http://www.apple.com/quicktime/download/win.html
Download it again. And install it again. Itunes should now work.
If it doesn't, for Video problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'File Types' -- check here to see if the file format of your problem video files is selected.
For Audio problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'Audio' -- Here you will see a Device is needed that will play your sound. Select 'Audio Playback and Recording Devices', If you are having an Audio problem it may be due to having no device or an improper device.
Good Luck
Nov 25, 2009 | Dell Dimension 9200 PC Desktop
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Aug 30, 2009 | Edirol UA-4FX External Sound System
I recorded my guitar audio, but I am unable to hear it. What is the problem?
You might check your system sound settings for recording and playback. Often the device selected for recording is muted so that you do not get feedback.
For example, a microphone would be muted as a playback device when selected as a recorded device. This might be what is happening to your guitar audio input.
Jul 30, 2009 | Sony Acid Music Studio 7 Full Version for...
Cant find audio device
it sounds like you've lost your sound card drivers.
you will have to check by going into the device manager witch is in :start menu /control panel / system / hardware / device manager & then go down to audio & video devices if it has a yellow ! on it then right click on it & uninstall it then when its done right click on it again & scan for hardware changes the yellow ! will repair right click on it again & update drivers the ! should disappear restart the system then it should be sweet.
Jan 06, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My computer cannot detect multimedia audio controller
Download Microsoft UAA driver then install it
Uninstall any sound driver first then
Go to device drivers and update your sound driver will go on net and find them and install them
Nov 01, 2008 | ASUS P5S800-VM Motherboard
Cakewalk SONAR Home Studio 7 XL for PC  Logo
292 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
